Question about Kohler Home
Toilet bowl will not refill
After unclogging toilet, the bowl does not refill completely then drains down to 1/4 normal fill level
    Scholar:
    New Friend:
  • 73 Answers
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Posted on Apr 24, 2014
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
  • 308 Answers
SOURCE: super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Posted on Jun 17, 2009
  • 10 Answers
SOURCE: Replaced toilet fill valve - now bowl water level a bit lower
put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
snap101
  • 117 Answers
SOURCE: Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Posted on Aug 01, 2009
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
Tip
Empty Toilet a Bowl
Anytime you want to remove a toilet, you're usually facing the problem of how to get the water out of the bowl.
First, turn off the water
Flush, and hold the lever down until it has nothing more to drain out of the tank.
But then, you're still stuck with a full bowl of water.
Here's the trick
Fill a bucket with about 1 to 2 gallons of water.
Pour it fairly rapidly into the bowl all at once.
Because of siphon action, and nothing to refill, it will drain 90% of the water out of the bowl, leaving about a cup of water in the bowl.
If you have to have it completely empty, you can use a small hand pump, but in most cases, it's low enough for you to just carry out the way it is.
on Mar 26, 2010 | Plumbing
Have a new 400A and water level is normal in the tank : upon flushing the bowl fills almost to an overflow?
What's wrong with that that's were it should be.with a 2.5 gal tank that water level is corect.Iff think that's too much, adjust the water level adjust clip, by sueezing clip and move it down to adjust the water levelto lower.
Sep 10, 2014 | Fluidmaster 400A Toilet Fill Valve Cap
How to adjust fluidmaster
There should be a small black rubber tubing piece that connects to the fill valve and the other end goes in the overflow tube to refill the bowl after each flush. Make sure this tubing is installed correctly and that should solve the problem. Hope this helps.
Bob
Jul 03, 2014 | Home
Toilet fills with water then slowly goes down
you have a blockage maybe outside in your shores
Oct 16, 2012 | Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Super low water level in bowl decreases after flush refills
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Home Logo
157 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
