Question about Samsung WF328AA Front Load Washer
Instructions on changing water pump on a 1999 mercury mystique gs 2.0L
    Scholar:
    New Friend:
  • 156 Answers
Well honestly I hope you're somewhat mechanical inclined...jack up car, remove right front wheel, remove inner wheel well, remove coolant overflow bottle, remove belt, remove harmonic balancer from crank, this allows access to remove pump, support front chassis with jacks,2, remove both front and rear chassis bolts, remove engine mount bolts,now the fun part, you have to jack body up SLOWLY, until you have room to remove pump from underneath the vehicle.if you have an engine cradle that would work out best.problem with this vehicle is there's no room, which im sure you already know.labor time for a shop to fo it is around 3 hrs plus parts...it can be done by D.I.Y but be careful and take your time. .im sure someone may chime in with an easier way, im just going by the book...good luck
Posted on Jun 14, 2014
Do you have to remove the timing belt to replace the water pump on a 1999 mercury mystique gs 2.0L
  • 1 Open the hood and disconnect the negative cable terminal from the battery using a wrench. This is the cable connected to the post with the negative sign next to it.
  • 2 Place a large drain pan under the radiator, open the radiator drain valve and loosen the radiator cap. Allow all the coolant to drain from the radiator and then close the radiator valve. Remove the drain pan from under the vehicle and cover it if you plan to reuse it later.
  • 3 Unfasten the two bolts from the top engine cover, which shields the water pump pulley. Use a ratchet, short ratchet extension and socket. When removing the cover detach the crankcase ventilation tube from the edge of the cover by hand.
  • 4 Raise the front of your car with a floor jack, support it with two jack stands and chock the rear wheels with a couple of wooden blocks.
  • 5 Rotate the drive belt tensioner clockwise using a breaker bar with a 3/8-inch driver. Insert the breaker bar driver in the square hole of the belt tensioner. Hold the belt tensioner in the release position and lift the drive belt from the pulleys. Slowly release the belt tensioner to its original position.
  • 6 Loosen the clamps holding the two hoses to the water pump using a Phillips-head screwdriver and detach the hoses from the water pump.
  • 7 Unfasten the three bolts that hold the water pump and housing assembly to the engine using a ratchet, short ratchet extension and socket. Remove the water pump from the engine.
  • 8 Unfasten the water pump body from the water pump housing bolts using the ratchet and socket.
  • Installing the water pump. 9 Remove old gasket traces from the mating surface of the water pump housing using a plastic scraper. Install a new water pump gasket following the instructions of the new pump manufacturer.
  • 10P osition the new water pump in place over the housing and install the mounting bolts by hand. Tighten the bolts to 18 foot-pounds using a torque wrench and a socket.
  • 11 Place the water pump assembly in position on the engine of your Mercury Mystique and install the new bolts (part number W701544) by hand. Tighten the bolts to 13 foot-pounds using the torque wrench, short ratchet extension and socket.
  • 12 Rotate the three water pump assembly bolts clockwise an additional 95 degrees using the socket, short ratchet extension and a degree wheel.
  • 13 Attach the two hoses to the water pump and tighten the hose clamps with the Phillips-head screwdriver. Reinstall the drive belt using the breaker bar.
  • 14 Lower your Mercury Mystique off the jack stands.
  • 15 Replace the top engine cover with the ratchet, short ratchet extension and socket. Refill the radiator with coolant and tighten the radiator cap.
  • 16 Connect the battery cable to the negative battery post using the wrench. Start the engine, check for coolant leaks around the water pump and add more coolant to the radiator, if necessary.
Apr 22, 2014 | Mercury Mystique Cars & Trucks
Labor hours to replace water pump on 1999 mercury mystique gs 2.0L
Is rather costly $300 plus parts but you can do it yourself for less than $100 including parts.
Apr 15, 2014 | 1999 Mercury Mystique
Do you need to replace the timing belt when you change a water pump for a 1998 mercury mystique v6?
You don't have to replace it but you have to take the belt off to remove the water pump for the extra $30.00 i would recomend changing the belt too, unless the belt has been changed less then 20,000 miles ago .
May 09, 2011 | 1998 Mercury Mystique
How can I get instructions on how to change a fuel pump on a 1999 Mercury Mistique
you can buy a repair manual, these go for about 10 bucks on ebay. step by step instructions with pictures is what you need.
Mar 09, 2011 | 1999 Mercury Mystique
So I have a 99 mercury mystique gs, cars running great then all of a sudden I'm driving one say and temp gauge gets hot, so I pull over and the resivour is completely full like almost near the very top of...
I would flush the radiator and replace the thermostat, and then see if the problem persists. if it does then I would look at thermostat sensor and possibly the water pump. Hope this helps Tim
Aug 29, 2010 | 1999 Mercury Mystique
Replacing the belt tensioner and serpentine belt in a 1999 mercury mystique but the belt is still loose how do I get it to tighten
You either have the wrong belt, or it's not on correctly. Make sure all of the pulleys are secure. (Like the power steering pump support bracket isn't loose) The diagram for the belt is usually under the hood.
Nov 24, 2009 | 1999 Mercury Mystique
Smelled mild burning, lost antifreeze - engine temp Hot. I looked under car and noticed a serverly frayed Belt - NOT the big surpentine belt - another small belt on the driver's side. 1999 Mercury Mystique...
For the 1999 Mercury Mystique Water Pump Belt on 2.5L V6 Engine:
Probable Causes: Belt: worn out, started slipping. Overheating caused by failure of Belt. Lost antifreeze: caused by failure of belt, not turning Water Pump Pulley, not circulating anitfreeze, which resulted in overheating.
Click on the following free direct Link. It has the Serpentine & Drive Belt Diagrams and Tensioners for your 2.5L Engine.
Scroll down the Page (about 1/3rd down) to Diagram #G99H08189, it shows the specific Water Pump Belt.
Note the Tensioner.
http://www.2carpros.com/car_repair_information/year/1999/make/mercury/model/mystique/1999_mercury_mystique_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
Jun 03, 2009 | 1999 Mercury Mystique
Timing marks
Probably arent any as the timing is controlled by a crankshaft position sensor and is not adjustable.
Jan 13, 2009 | 1999 Mercury Mystique
Samsung WF328AA Front Load Washer Logo
21 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
