Question about Metrokane Rabbit Electric Wine Opener
LCD display wont work
How can we get the display to show number of bottles opened?
Seimens extraklasse dishwasher fault
What is the model number of your unit?
Nov 20, 2012 | Washing Machines
Whirlpool fridge/freezer LCD replacement
What is the model number listed inside the refrigerator section?
Nov 17, 2012 | Refrigerators
My nokia N96 wont display the screen but still turns on and all buttons light up and sound still works. How could i fix this?
You have to check that your LCD is connected to the buttons strip from inside of your phone by opening its front casing. If it is in the strip connector, then you ave to change your LCD as your LCD had been over to show any thing.
Oct 18, 2009 | Nokia N96 Smartphone
My olympus 1050 got wet i dont really know y,it wont show anythin
You may want to call Olympus Customer Service and discuss the repair policy with them. Sounds like if water got in the camera somehow may have shorted something out. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 10, 2009 | Olympus Cameras
The LCD of my nokia3230 wont work
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
Mar 09, 2009 | Nokia 3230 Cellular Phone
New laptop lcd display not working
check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Feb 18, 2009 | Gateway MT6451 Notebook
Error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Jan 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
PANASONIC FA-A505
FA-A505 is the Automatic Doc Feeder number and not the copier model number. Without knowning the machine model number, This is just a general code for 95% of the Panasonic Copiers that use this code. If the U14 is flashing on machine, then check your waste container bottle for the toner. (Not the toner bottle, there should be a waste container that needed to be changed or at leasted emptied and then washed out with COLD water) Be warned.. washing the bottle out will make a mess out of your sink, so it is suggested to do in in a basement tub/sink.
If you do not have another waste container, then empty as much of the used toner in a plastic bag, and then rinse the bottle out. The bottle does not have to be completely dry when you re install it. Just shake as much of the water out as possible. If the U14 goes away, you are good to go. If the U14 is still showing, open the door and remove the bottle and see if you can close the door WITHOUT the bottle. If the U14 goes away, then the bottle is not clean enough. DO NOT RUN THE MACHINE WITHOUT THE BOTTLE, or you will have a mess in your machine. (some models will let you close the door without the bottle, and some wont).
Your best bet, is to replace it with a replacement container if your church has one and order some spares to keep on hand.
Hope this helps.
Good luck
Feb 02, 2008 | Office Equipment & Supplies
Metrokane Rabbit Electric Wine Opener Logo
74 people viewed this question
Top Metrokane Home Experts
john h
Tom Chichester
Are you a Metrokane Home Expert? Answer questions, earn points and help others
