Question about Royal 160MX Shredder
I have a royal shredder modle MP220 the motor is running but it doesn't will not pull the paper in . I cleaned it out and still nothing .
I took it apart and cleaned it out still not working.
  • 3 Answers
SOURCE: Gears won't pull paper through
http://www.geocities.com/jayrespler2/index.html
Posted on Nov 29, 2008
  • 133 Answers
SOURCE: Paper no longer feeds in. Motor works.
Please check the sensor is on or off.
if paper is feeding completely then it means you need to buy a new one.
Posted on May 23, 2009
  • 8 Answers
SOURCE: Shredder motor runs but gears are not engaging and
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Posted on Aug 08, 2009
  • 19 Answers
SOURCE: Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
Posted on May 30, 2010
  • 1218 Answers
SOURCE: How do I go about getting replacement plastic
For Royal parts and prices give Royal a call at 1-800-524-0799.
Posted on Aug 21, 2010
I have a Royal Mp220 paper shredder the motor hums when you put the paper to the blades it doesn't shredd the blades do not turn .
To begin with I'll explain that I'm not familiar with your shredder at all, but what you describe might be the same thing I've seen on other shredders. Many actually have a second hidden switch which serves as an interlock to make sure the unit is properly seated in the catch basket. In most cases its located a corner and the catch basket actually has a small shelf to press the micro switch in that location. I'd suggest you examine the bottom side of the shredder to see if you can see a small switch that also needs to be pressed.
Apr 24, 2014 | Royal Office Equipment & Supplies
The motor will hum when you put the paper to the blades but it will not shredd because the blades do not turn.
Blades need to be cleaned and oiled Unplug and check to make sure there are no staples or something caught in the gear edge in the corners You should be able to turn it by hand If not the gears inside probably slipped out of place or got busted from somebody trying to shred too much at once
Apr 24, 2014 | Royal 160MX Shredder
It is possible the blades are running in reverse. If the motor is running and the blades are turning without putting paper in, check the position of the switch. The motor should not turn on automatically when repositioning the switch. Reposition the switch so the light is on, but the motor does not run. Then try to put in paper. I hope this helps.
Apr 19, 2014 | Royal 160MX Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
SHREDDER WAS JAMMED TOOK PAPER OUT AND NOW SHREDDER WON'T TURN ON
If its dead and you have no lights and nothing runs then probably the PCB inside is gone...give Royal a call at 1-800-524-0799 for parts assistance.
Sep 13, 2010 | Royal Office Equipment & Supplies
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
My shredder quit working.
First thing you have to do is clear all jammed paper. Second..try running machine; if the motor runs and the blades turn put some shredder oil into the cutting blades as lubricant. If the motor wont run you have probably blown the pcb because of too much paper... to get replacement part call Royal at 1-800-524-0799.
Jul 15, 2010 | Royal Office Equipment & Supplies
May 25, 2010 | Royal 85X Shredder
I have a royal shredder model 160mx. motor is
Check if its just dirty "eyes"...they are in the middle where you put the paper in; clean them with a soft cloth ( unplug the shredder first.)
If that dos'nt fix it then it could be defective "eyes" or the pcb...you can call Royal at 1-800-524-0799 for parts and prices.
Jan 12, 2010 | Royal 160MX Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Royal 160MX Shredder Logo
165 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
