Question about Alesis Computers & Internet
I have alesis 10|2 interface,i tried downloading the suitable driver,i had it working in fl studio 11,but when i turned on my laptop and went into flstudio11 to try and record,it doesnt work,when i pl
Toshiba satellite laptop windows 8
  • Alesis Master
  • 10,291 Answers
Did you get the windows 8 version of the driver? If so uninstall the driver and reinstall it. If not, then you'll have to get a windows 8 driver.
Posted on May 07, 2014
SOURCE: tascam US-122 USB Audio/MIDI interfaces driver
the software is made by Steinberg and uses ASIO drivers that are at the address i gave you http://www.tascam.com/details;9,15,69,19.html
works fine on my XP machines
Posted on Dec 14, 2007
SOURCE: US 122 BSOD Computer crashes BUGCODE USB DRIVER
I had this problem on my HP DV6000z.
It is INDEED the power to the USB port. When you start to use the Tascam, it demands power and then you get the BLUE Screen.
I updated my BIOS, made sure that ACPI Power Management was installed and it sorted my problem out.
Microsoft also refers to this problem and suggest XP SP2, but if that is already installed (which i presume it is) then they can;t help any futher.
Best bet it to update your bios. Or get a USB HUB.
Posted on May 13, 2008
  • 4 Answers
SOURCE: Lose sound on my Toshiba laptop
you did the right thing by going to control panel and opening the sounds and audio devices tab. The fact that you said that everything is dulled out or frozen leads me to beleive that it's the sound driver. Sometimes they get damaged from third party software. So go to my computer, C: drive, open the windows folder. Now click on a folder that says drivers. Inside that folder you should have a file or folder that has your sound driver to install. That's the easy way.
#2 also easy. Go to toshiba.com support and downloads type in your make and model and you should get a list of your drivers. select the audio driver and download it and install. Sounds easy right!!
#3. Not that easy. right click on my computer, go down to properties and then click on the hardware tab. Now click on device manager. Here is a list of all the hardware in your computer. If it has a yellow exclamation mark next to it, then windows does not recognize it! So look for sound video game controllers or multimedia in the list. This is where the drivers for all of your sound is. Click the + sign next to them. This should give you a list of audio drivers if present. If you see a yellow question mark next to them then you must reinstall your drivers by right clicking on the question mark and choosing to update driver. this should bring you to the hardware update wizard. Select not this time and then next. now choose install the software automatically and then click next. If windows has a driver for your sound card stored internally it will now reinstall it Hope I helped you out somewhere.
If none of the above solutions work then it might be a hardware issue. It also might be disabled in the bios. Good luck
Posted on Aug 22, 2008
sgoswami
  • 114 Answers
SOURCE: I have a new ALesis
Check the link to download the driver and check if it work :
http://www.alesis.com/io2
Regards Soumajit
Posted on Oct 13, 2009
SOURCE: sound doesnt come out from guitar link UCG102
what you need to do is install the asio4all driver then select file, adio midi settings and where it says behringer audio codec click the arrow and select asio4all then click the configure button and in the wdm list you must activate all the items under audio codec and the audio speaker under High Definition audio device this will allow it to work through the speakers, or just leave it how it is and plug in a set of headphones. make note though that your speakers will play nothing else but the guitar sound. all other music internet sounds, the lot will no longer work as your ucg102 is high jacking your sound card to produce the sound from your guitar. hope this helps.
Posted on Jan 28, 2010
MD-1700 keyboard. How do I connect it via the USB port on the computer?
MIDI(Musical Instrument Digital Interface) is a standard data transfer system used exclusively for instrumentation. A side from amps 7 recording equipment many PCs, laptop & TVs have MIDI access built into them. If they can interface with a UBS connection it is more likely the exception rather than the standard. Below is a link to the users manual for your keyboard. Start reading on page 39.
http://www.manualslib.com/manual/593746/Radio-Shack-Md-1700.html?page=38#manual
Aug 05, 2015 | Image Line FL Studio 8 Fruity Edition Full...
Alesis io2 guitar inpu and mute playback for backing track in audacity
Audacity is a copyrighted audio source and does not permit you to record tracks or playback of any kind. you will need to D/L the audio file you are trying to record in tangent and then play them together through an audio remixing app, like Ableton live or FL Studio
Jan 28, 2014 | Alesis iO 26 Sound Card
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Check the midi channel. It needs to sync to FL Studio. Channel settings you'll need to look up in the privia manual...can be laborious - but worth it in the end :)
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Hello, I recently picked up a Tascam us-144 MKII. My OS is windows 7 32 bit. And we run FL studio 10. While playing some of our tracks every once and a while we experiance loud cracking and popping sounds...
Hello you can download drivers and the manual here:
http://tascam.com/product/us-144mkii/downloads/
You need adobe reader to read the content in the manual.
It sounds like the gain or mic level is set too high or a defect cable.
Try also to renew the sound driver on the pc.
Try also to lower the the input gain on the playback device.
The FL studio homepage:
http://www.image-line.com/documents/flstudio.html
Good luck
Dec 06, 2012 | Computers & Internet
I need help with running my alesis fireport 1394 with windows 7
Either use the legacy drivers for your 1394 interface or do as I did and just download HD24 Tools program until Alesis makes a device that works on modern operating systems! Don't stay up late waiting for Alesis to do that. Ask yourself when the last firmware upgrade for the HD34 was.
Feb 02, 2011 | Alesis Fireport 1394 for ADAT HD24...
Problems Alesis I/O1
If the port is built-in on a motherboard, then the best solution is to purchase a PCI firewire card, and dis-able the old one in the Bios. (if it is on a laptop, then it needs factory service).
May 26, 2010 | Alesis iO/14 Portable Firewire Audio...
My Alesis stopped working!!
it might have a fuse in it if not its prob. an amp inside
Dec 27, 2009 | Alesis io 2 Portable 2-Channel 24-bit...
FL Studio doesnt open.
Make sure it is allowed in firewall and all drivers are downloaded and program is enabled.
Jul 20, 2009 | Image Line FL Studio 8 XXL Full Version ...
Pinnacle Studio Plus version 10 Keeps Crashing
If you are getting any type of error message or warning message (except a fatal crash message), then , click here to see the FAQ titled "Studio Launch error/warning messages" to resolve these issues. For a fatal crash or any type of lockup/freezing while launching, continue with this FAQ, below.
If Studio was launching for some period of time and then it stopped launching, it is best to try to determine what changes have been made to the computer recently and undo the changes to see if it has an affect on the problem. Here's a short list of what could affect Studio's ability to launch:
  • A Studio patch was applied but it didn't install properly
  • The graphics driver was updated
  • Hardware was installed
We recommend using Windows XP System Restore. You can obtain more information on how System Restore works from the Microsoft web site at:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Troubleshooting steps for Studio hangs or crashing while launching (starting)
1. RESTART THE COMPUTER. Try restarting the computer
2. WAIT A FEW MINUTES: If Studio still won't launch, wait a few minutes to let it finish launching. We have noticed on some computers that it may take a little while for Studio to completely launch. Studio 10 users click here to see the FAQ on this.
3. LATEST VERSION OF STUDIO. There was a launch problems in previous versions of Studio 10 that are now fixed in the latest version. When troubleshooting any problem, it is always best to be on the latest version of the software.
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
If you have Studio version 10, download the latest version here .
Note: Studio 11 patches will only patch a previous install of Studio 11. Studio 10 patches will only patch a previous install of Studio 10. Etc.
If you have an older version of Studio (Studio 9 or 10, etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
4. SAFE MODE: Try launching Studio in Safe mode. In Safe mode, many device drivers and applications do not load. If Studio will launch in safe mode, then the issue is most likely a configuration problem with your computer. NOTE: We do not recommend using Studio in Safe Mode. This step is for testing purposes only. To start in Safe mode:
  • Shut down the computer
  • When you turn it back on, tap the F8 key every couple seconds until a menu pops up. (If the XP splash screen appears, the F8 keys was pressed too late so restart the computer and try this step again)
  • On the menu, choose Safe Mode, and then press the Enter key
  • Launch Studio
If you need help starting in Safe mode, you can click here to get information on Microsoft's web site
If Studio won't launch in Safe mode, then Studio many not be installed properly or the install may be corrupt. We recommend uninstalling and reinstalling Studio.
Click here to see the FAQ on how to uninstall, then reinstall Studio 10.
Oct 22, 2008 | Pinnacle Computers & Internet
Open Questions:
Computers & Internet Logo
107 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
