It was working fine when it had no display lights now when I try to use and press buttons some of them work the others just cause the oven to keep beeping.
SOURCE: clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
SOURCE: Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
SOURCE: F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
SOURCE: F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2
Oven
too hot
Replace
relay
board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
SOURCE: self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
