Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Very slow cold water fill, why?
When filling the cold water is alot slower than the hot water cycle
  • 770 Answers
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Posted on Jun 19, 2009
  • 23 Answers
The screen in the fill valve is probably clogged. Remove the cold water hose from the washing machine and clean out the filter/screen inside the valve.
  • Annette Noak
    Annette Noak Oct 26, 2013
    How hard can I pull on that small screen?
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Washer not taking in water in wash and rinse cycles in cold cycle
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | KitchenAid KAWS850L Top Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Cold water fill is very slow and makes strange sound
check with the plumbing work if that is fine then better take it to the dealer to change the inlet valve. attempting to change by yourself can cause other complications.
Oct 04, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
Oct 19, 2008 | Maytag Washing Machines
Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
323 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
