Question about Philips Audio Players & Recorders
Fw 396c cd tray stays out wont close - Philips Audio Players & Recorders
Arpi
  • 326 Answers
SOURCE: Durabrand W600-S cd tray wont open
Hello, this kind of repair requires certain skils and knowledge about the cd changer mechanism. Please claim for an in warranty repair or replacement of the system. If you need more info please advice. Arpi
Posted on Jul 17, 2007
SOURCE: FW-C870 NO FUNCTIONS
The solution I received for my TEAC DC-payer's CD stuck in it and the door did not open, was absolutly the best. I pushed the reset button at the back and it WOW worked.
Thanks to your FIX IT TEAM.
Eva_
Posted on Feb 10, 2008
  • 899 Answers
SOURCE: cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Posted on Oct 16, 2008
  • 74 Answers
SOURCE: model number FW-R8/37
you must bring it to a service center there is nothing else you can do
Posted on Dec 16, 2009
hardrocko
  • 1476 Answers
SOURCE: Cd tray wont close, cds wont play
Sounds like you probably have a stretched belt on the load motor. Unplug the unit and remove the case which will expose the load motor. Plug in and turn on and press tray in button. You should hear the motor run and if you can see the belt you should see it slipping. Some belts are easy to change, and some are next to impossible. If you have to disassemble anything be sure that you note the position of everything as the timing of the tray, door, laser and most items in the unit is very critical. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Posted on Feb 20, 2010
My cd tray wont stay closed. it opens a few secons after i close it.
Don't worry dear user this problem is creates when we using a long time are cd/dvd writer but if have this type problem please reinstall your cd/dvd driver and your problem can be solved........
Jul 04, 2011 | Dell Studio 15 Laptop
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Cd tray not staying closed
Oct 16, 2008 | Memorex MKS5001 Shelf System
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Cd tray on my 360 wont stay shut
either you will need it repaired or u can do it the cheap way and after the disc tray is shut put some tape over it and see if it will read it still. If not it will need to be repaired. It will only cost about $35 or free if you are still under warranty.
Feb 14, 2008 | Microsoft Xbox 360 Console
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
