Preamps, turntable and 24bit / 96kHz recording
Should i buy a preamp for my turntable if i want to record 24/96? I can record now with straight line in to my sound card and the volume at 100%. On occasion some song have a noise floor that is very close to the audio (low recording) when that happens it makes me thing I should get a preamp. I don't want to get one that will limit my recordings (I need to record at 24/96) or that costs a small fortune since this is a one shot deal to record my vinyl then sell it. I have seen cheap ones on Amazon. Such as this: http://www.amazon.com/gp/product/B00025742A/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=175P8RZZQ8QG8KA076VG&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846 but it says it does 20Hz - 20kHz.
    Problem Solver:
  • 5 Answers
You need an ADC ( analogue to digital converter) along with a phono preamp to restore the RIAA correction to the turntable output. Check out musicdirect dot com for some examples. Alpha Design Labs makes a great one that retails at $500.
Posted on Jul 07, 2014
SOURCE: Amp 100 Line 1 in problem
This
Posted on Apr 27, 2008
robotek
  • 1512 Answers
SOURCE: LOW VOLUME ON MY SL-B35 TURNTABLE
Hi Tim,
You probaably do not have a phono input on the digital surround amp you are using. Your sound is bad for 2 reasons
  1. Your Turn Table has low output level,about 100 times less than a CD player.
  2. You need RIAA equalisation to reduce the treble and boost the bass. This is for replaaying any modern vinyl or LP's
You can get an outboard preamp that matches the output of your T/T to suit the normal aux input on todays digital surround amp.
You can get one online from here. Or if you are keen build one from a circuit here
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 24, 2008
robotek
  • 1512 Answers
SOURCE: Preamp noise
Hi KenO2
First thing to check is that the phantom power is not turned on. If you are using a condenser mic, then it should. If you are using dynamic mic, then it will crackle and makes weird noises in the manner you describe. Other than that it sounds like you have a failing op amp in your preamp. This sort of repair work is not expensive(with respect to the outcome). I would anticipate $40-60 to fix it. Trouble is you can replace it super cheap at the moment 45% off for $64.95plus $9.95 shipping from zzsounds
So I guess that it may not be worth repairing, and more a replacement item for that money. If you have a mate with electronics experience, you could just replace the opamps at home for $10 worth of parts.
If you think my advice helped you to work out what to do, a FixYa rating would be great. Cheers
regards
robotek
Posted on Jul 21, 2008
  • 24 Answers
SOURCE: LED light dont come on!!! Pioneer audio receiver VSX-9700s
Do you mean that the display that show the audio source or mode doesn't turn on? Try shining a bright flashlight at the display and see if you can read it. If you can, then the backlight light bulbs have died.
Replacing it will be a pain but you may find a usable replacement at Radio Shack. Just measure the voltage that goes to the bulbs and find one with similar ratings. They are probably 12v lamps.You will need to remove the display from the front panel of the amp and desolder the old lamps. Getting at the bulbs is the hardest part.
Posted on Dec 28, 2008
  • 4234 Answers
SOURCE: Looking for schematic for a Behringer MX-9000
If the mic preamp ICs are getting destroyed, there is something else wrong. Look for the correct B+ and B- voltages. I suspect that there is an offset here that is stressing the ICs to the point that they fail. These ICs should be 4558s or something similar and are readily available for low $$. Contact Beringer directly for the ribbon cable.
Dan
Posted on Mar 22, 2009
How to record
This is the Amplifiers & Preamps section. You can't record with just an amp or preamp. You need some kind of a recorder. If you have a laptop, it probably has a built in microphone. This provides the simplest modern way to get sound recorded as a file. You can also record from the microphone input on the side of a laptop, or on a desktop computer. Without knowing what equipment you have I cant offer any more detail. Audacity, a free program, might be useful. Google it.
Apr 14, 2016 | Audio Players & Recorders
Record Vinyl 24bit / 96kHz and use a preamp
Get your hands on a
DOD R-855, 4 Channel Stereo Preamp Mixer
You shouldn't have any problems!
Apr 19, 2014 | Audio Players & Recorders
Denon pma 250SE phono problem
Denon PMA 250SE does not have a RIAA phono preamp.
for some info about these preamp and details here;
Phonopreamps.com Home Page
Note: Choose a better quality regulated power supply,
for these preamps.
Although an updated turntable with USB can be used
without the need of such RIAA phono preamp.
Jul 26, 2012 | Denon Audio Players & Recorders
How do i assign a record player to ''aux ''input terminals of a denon avr 1507 amplifier
Depends on the record player (turntable). If it's old-school it will need a PHONO preamplifier to raise the level and frequency-balance the output according to the RIAA curve. Otherwise it will be uselessly low in volume and tinny sounding.
Phono preamps are available at a lot of electronics stores online. Google it. If you have an old school receiver with a PHONO function you could use IT for the TT and send its output to the Denon.
If it's a newer TT it may have its own internal (selectable) preamp. Then it would drive any standard Line Level audio input.
Apr 26, 2010 | Audio Players & Recorders
I can barely hear the record when played on my Stanton T.52
Is this a sudden onset problem or has it always been like this?
A traditional turntable requires a Phono preamp inline with it to PRE amplify and frequency-balance the minute signal produced by it's cartridge for later amplification by a power amp. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Recent AV Receivers generally do not.
You don't say what electronics you're running this through. I suspect you have it jacked into a Line Level input instead of a specific Phono input. The result would be very low, tinny sound.
If so, you need to get a Phono Preamplifier.
Feb 19, 2010 | Stanton T.50 Turntable
Using mac with the ion turntable to record vinyl--it records fine and imports into itunes, but when I play songs back I cannot hear any sound. Computer is set to 'line in' for sound input and 'internal...
Funny thing about analog to digital recording without a preamp. You will record a signal, but that signal might be below the level of human audibility, if the line levels are left at the level that left the turntable, given the absence of a PREAMP.
Apr 28, 2009 | ION Audio iPTUSB Turntable
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
No Phono setting?
Hi dtrain
Phono preamps are are considered to be a thing of the past by most main stream manufacturers, so they leave them out of modern amps... supposedly saving some expense in manufacture also. -the i generation mostly dont even know what vinyl is ... poor souls. The good news is you can get decent "bolt on" preamps to listen to your favourite records. It plugs in line with your turntable and aux input on your amp, and generally uses an external power source. you can go to here and get one online starting at around $30 plus delivery.
good luck, happy turntabling:)
regards
Graeme
Mar 09, 2008 | Pioneer VSX-D511 Receiver
Purchased technics sl-bd20d what else do i need just to play records ?
well the mixer is optimal way if you are planning to buy another one sometime but if you are to have only one then you need a corrector which changes the signal (preamp)
just ask for a corrector and say your problem in any tech-shop they will help you..
Dec 18, 2007 | Audio Players & Recorders
57 people viewed this question
 Grubhead
Grubhead
