Question about Pioneer PureVision PDP-4304 Television
Hdmi input not working
I plug in the hdmi cord from my cable box to the tv and only get a flashing pink,red,snowy screen. I've tried different hdmi cables, different tv sand different systems and those all work fine. Does that mean the hdmi input is broken and if so is it fixable
  • 4 Answers
Do you have a second signal from your cable box going into the TV by a different port?
You can only use one or the other, not both.
Posted on Apr 19, 2014
  • 1153 Answers
SOURCE: please help
Could also be the cable, set are now designed if no signal to shutdown, so first check media box by calling cable company and or replace and try another just to make sure.
Posted on Aug 27, 2007
dsacco86
  • 1077 Answers
SOURCE: Pioneer PDP-4340HD TV Media Receiver installation
With the cable splitter problem, I believe they used that idea to use the Antenna/cable A & B ports to watch digital and anolog TV.
Port A for Anolog and port B for Digital.
Posted on May 25, 2009
  • 50 Answers
SOURCE: My HDMI Terminals for Pro-Ro6u Media Receiver is
This could be an HDCP "hand shake" problem. Try turning both the TV and the connecting device off, connect the two using HDMI, turn both of them back on, select the proper input and see if you get a picture. If nothing happens try the other HDMI inputs by following the steps listed above. I hope this helps.
See the following Thread for more information about problems with the Pro-Ro6u.
http://www.tv-forums.com/forum/TV_Equipment_C4/TV_Repair_Forum_F3/Pioneer_Pro_RO6U_Media_Receiver_P46635/
Posted on Feb 08, 2010
tgr2000667
  • 30 Answers
SOURCE: I cannot get the Input
input is shared with component input--one or the other --must choose in set up menu
Posted on Jul 13, 2010
SOURCE: Pioneer PDP-6020 FD, Menu items grayed, no HMG after firmware upd
I have the same issue - Pioneer told me the local repair shop could reset the firmware, I paid the $90 service call and they could not fix anything. For a 18 month old $5000 TV they now want me to replace the digital board for around $500.
Posted on Nov 24, 2010
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
HDMI to DVI gives pink screen
try a regular video input on the tv and on another tv, and if that pink is on both tv's then its the dvd but if it only does it to that tv your hooking it up to then there is a problem with the tv video input
Oct 12, 2008 | Televison & Video
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Turns on but blank screen just says no signal. Also blinking red light
If you have an lcd or modern thin screen tv, go into your menu and make sure your input selection is correct. If you're hooking up to a cable network, you will want to select the HDMI input coming from the cable box (HDMI 1, HDMI 2, etc.). This is for the newer cable systems that have the HDMI cable plugged into the tv. If you have the older, bnc connection (round with a wire in it), you will have to select TV or the input.
If all of the input selections are in order, you could have a faulty cable, or a bad cable box. Try to swap the box out with another tv, if available, to verify if the box is, indeed good.
If you have a standard tv, check the cable box on another tv, also, and swap out the cord to check it, also.
Otherwise, if the cable box is good, and the cords are good, you may have a problem with the tv itself, in which case servicing will be required.
Good luck, and hope this helps.
Apr 25, 2011 | Televison & Video
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
I have a dish network satellite box with an hdtv. It works well with the red/white/yellow cables and the blue/greened cables together but when I use only the hdmi cable I don't get a picture or sound on my...
I definitely hope that you have gotten this resolved, but if not, here are some reasons this could be happening. If you have tried the same HDMI cable on other devices, such as the PS3, then it sounds like the problem is in the HDMI output on the receiver. Have you tried another HDMI cable in a different input on your tv? It could also be the input on the tv. But so far, it does sound as though this is a receiver issue, and the receiver would possible need to be replaced. You can e-mail me if you have any additional questions. My e-mail is becki.barned@dishnetwork.com.
Becki Barned
DISH Network Customer Service
Jul 21, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
Pioneer PureVision PDP-4304 Television Logo
119 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
