Question about LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator
Water tastes bad from LMX28988 refrigerator - LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator
    Problem Solver:
  • 19 Answers
This is usually attributed to the filter needing to be replaced... once a new filter has been inserted it should clear up the taste problem.
Posted on Apr 19, 2014
Testimonial: "We have changed the filter twice"
  • Blaine Anderson Apr 19, 2014
    The other problem you may have is that where the filter plugs in is blocked and the water is bypassing the filter... I would suggest you contact a technician and have them come in a blow out the line to clear any possible blockage.
The water and ice started tasting very bad with a sulfur chemical taste a few months after the water filter was replaced. What should I do?
Did you recently have a water main break in your area about the time the bad taste started or any plumbing repairs in the house?? Could be the filter is contaminated. Try another filter and go from there. If problem is gone it was the filter. If still there---possible problem with refrigerator water system and tubing.
Mar 15, 2015 | Whirlpool ED5LHAXW Side by Side...
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker is makeing bad tasting ice water supply is good no bad taste in water , can it be cleaned
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Oct 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Jun 23, 2009 | Refrigerators
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
67 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
