Question about LG LSC26905TT Side by Side Refrigerator
My water in my LG french door refrigerator taste awful. We changed the line, flushed with vinegar and water, changed the filter, and it still tastes bad. It tastes worse than water from the sink. We h
LG French Door LMX28988
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Try flushing using saturated salt water or lemon
Posted on Apr 19, 2014
    Problem Solver:
  • 5 Answers
Did you resolve your problem and what was the solution? Can you post it here for us to see? thanks
Posted on Jul 05, 2014
cj2176
  • 520 Answers
SOURCE: Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Posted on Jun 09, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Posted on Aug 05, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
SOURCE: I have a LG 3-door french refrigerator that will
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Posted on Oct 20, 2009
  • 161 Answers
SOURCE: LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Posted on Jan 24, 2010
Water tastes bad from LMX28988 refrigerator
This is usually attributed to the filter needing to be replaced... once a new filter has been inserted it should clear up the taste problem.
Apr 19, 2014 | LG LFX21971ST Stainless Steel Bottom...
Squeaky seal on lg french door
Just get some wd40 and spray the inches, as they have gone dry
Feb 16, 2014 | LG LFX25976ST 24.7 Cu.Ft. French Door...
My LMX289885T/02 LG refrigerator's left door will not close without manually pushing the long bar into place first.
Guessing your talking about the heater. Sometimes the sprin comes loose, in the end probably will have to change it out
Sep 08, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Refrigiator does not air culation
tihs is either a ice blockage on the cold coil or the evap motor has failed ... hope this helps mm feed back pls .. ,,
Jul 10, 2011 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Er if code comes on. I have let it defrost for 4 hours. Code disappears and then reappears. I would like to know how to fix it.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
I need an owner's manual for LG refrigerator LFC237605W. thanks, ed
Assuming you really meant LFC23760SW, you can download the manual at
http://www.lg.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC23760SW.jsp
Feb 14, 2011 | LG LFC25760 French Door Refrigerator
Refrigerator not cooling, screen reads ...error dh
Defrost heater error; If the heater malfunctioned that would cause ice to form in the evap and stop the fresh side from cooling properly. I read somewhere that those Sears ice box is nothing more than LG
I will give you a LG french door service manual to look at. Let me know if I am right:
LG FRENCH DOOR SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 08, 2011 | Kenmore 77554 / 77543 Bottom Freezer...
LG LSC26905TT Side by Side Refrigerator Logo
389 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
