Question about Kitchen Appliances - Others
I have lost instructions to my sisan steam iron and the measure cup. How much water and salt do I put in?
2 Suggested Answers
SOURCE: Lost directions for using my Sisan Steamer. I have
The measuring cup holds 1/4 cup. Fill with tap water and pour one full measure into the hole exposed by removal of handle. Then measure table salt into small hollow on handle. Next, pour two (2) full measures of salt into a second measuring cup full of water, and pour into Sisan. Never use more salt than will fill the measuring hollow in handle. Remember that should the steam cease, unplug and refill with two measures of tap water, but no more salt.
Maintenance:
Add one (1) teaspoon white vinegar to two measures of tap water, put it in the Sisan Steamer and let it run a few minutes. Then pour this out of the Steamer and rinse well to scale the inside.
Posted on Nov 20, 2011
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Where will i download instructions for sisan steam iron
http://www.ehow.com/how_4745214_use-steam-iron.html
Oct 18, 2014 | Irons
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wa
Nov 04, 2013 | Oreck Steam-It Steam Wand
Pump wont run
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
How do you run clean cycle - I have lost the manual
Self-Cleaning and Maintaining Sole Plate
Use the self-cleaning feature once a month by moving the steam lever back and forth from the "dry" setting several times. This will remove any residue from the steam valve and ensure that the steam system works properly.
Wipe the sole plate with a soft, damp cloth while the iron is cool and unplugged.
Run the iron over a cotton cloth several times to remove any residue from the sole plate.
Cleaning Anti-Calcium Feature
Fill the water cup that came with your iron. Use enough water to reach the Sunbeam logo in the top corner of the cup.
Add a teaspoon of salt to the cup and stir.
Empty the salt solution into the water reservoir in your iron.
Allow the iron to stand for 15 minutes, then empty out the water reservoir.Repeat this cycle with a second cupful of salt water.
Rinse out the reservoir with clean water. You should perform this cleaning once a month.
Jul 28, 2011 | Sunbeam Irons
Lost directions for using my Sisan Steamer. I have the water measure but don't know how much salt to add. Can you help?
Maintenance:
Nov 17, 2010 | Kitchen Appliances - Others
I have a rowenta da55 and lost the owners manual. I see where you put the water in. Do you use salt? It gets hot, but no steam.
Get some distilled water, (From any garage, the stuff you put in car batteries) and keep it in a plastic or glass bottle. It mustn't come into cotact with metal. This is best for your steam iron.
Sep 17, 2010 | Irons
Emson light weight iron on the handle says turro ''the iron that steams'' handle has measures of salt 2 add 2oz of water was moms but can not find how to use. can you tell me direction on where to find...
Remove the handle on the iron. Then fill the opening with two measures of table salt, using the handle's device to measure the salt. Add 2 oz. of water in the opening, then reattach the handle. Connect the handle and plug into an outlet. After a few seconds, the iron should begin steaming. It is then ready to use.
Apr 26, 2010 | Irons
Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Feb 12, 2008 | Irons
Kitchen Appliances - Others Logo
223 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
