How to program Simple Comfort AM7890 thermometer
I am really not understanding how to set this unit and I have the manual. Please break it down for me. Thanks
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I am looking for the
Please look this video which may help you. Thanks.
http://www.youtube.com/watch?v=fEppTCPBkOU&feature=related
Posted on Jan 08, 2011
SOURCE: Hi i have a simple
We're having exactly the same problem. I called ICM at 1-800-382-3113 and asked for tech support and they emailed the 2-page manual right away. I talked to Eric Wood, an Electrical Engineer there, and he sent it immediately. I hope this helps!
Posted on Apr 07, 2011
I borrowed a portable a/c unit Comfort -Aire model number PD121-5 cant get it 2 stay on cool it has timer & changes temp all the time. can anyone tell me how to reset this thing? No remote
some ac units portable or other wise use a program where it starts on full cool and as the humidity is removed from the room the program changes to less cool or switches off for periods ( called comfort mode on some units and is used for sleeping where the room temp is maintained and does't get colder as the night goes on)
try and down load a operators manual from the net
Jun 29, 2015 | Heating & Cooling
I have simple comfort 220il and the aux light and emergency light keeps coming on and it is green,do not know if that is normal or a problem with the thermostat?
The Aux light is normal and the Emergency light means you have pressed the emergency button by mistake to either bring your temperature up, or down. Take a look at your manual.
Jan 22, 2014 | Computers & Internet
How do you program a simple comfort AM7890-DHW thermorstat
Have you already searched the manufacturer's website?
Jan 16, 2013 | Heating & Cooling
Hi i have a simple comfort AM7890-DHW thermostat and my condo is just cooking. I know that the two settings are for heat and cold to kick in and i have them set properly but it still is not fixing the...
Apr 02, 2011 | Heating & Cooling
B zone is only cooling to 49 degrees and leds at L3 and L4 are blinking at 1 second intervals at circuit card on outdoor condensing unit. Is there a service manual available for download?
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Aug 02, 2010 | Comfort-Aire HMC18AD-1 Air Conditioner
The unit only goes down to 16 celcies
Its quite a low celcius setting A/C units are set around 21 deg for comfort. I would be uncomfortable at 16 deg c you really just want comfort cooling.
Jun 09, 2009 | Danby DPAC12031 Air Conditioner
I have a Vicks Thermometer, the comfort flex one, and it is not working properly. Everytime I turn it on there is a small triagle on the left side... I dont have the manual, so I dont know what that means.
Your battery is too low to allow it to operate properly, according to the manual. You can use a coin to remove the battery cover in the back to see what type of battery is needed to replace. Most drug stores like walgreens, etc, carry the watch type battery.
Dec 09, 2008 | Computers & Internet
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
