Question about Maytag Neptune Washing Machines
Were there recalls on any of ghese models
Water left in drum
    New Friend:
  • 19 Answers
The problem of residual water in front load washers is an on going problem. Some companies had put in a small drain hose in their units to alleviate the problem. Your washer is actually built by Whirlpool. There is no available auxiliary drain for these models. These are the suggested solutions to alleviate for your particular machine.
1. Leave the door open after wash completed. This will help to evaporate the residual water. If in an area where the door cannot be left fully open then place a towel over the top of the door to keep it from closing and that will help by keeping the door open a small amount.
2. To alleviate odor, pour one cup of bleach in the drum... DO NOT PUT ANY CLOTHES IN THE MACHINE! Put the washer through a wash cycle... some models had a clean cycle if your has this then use this cycle. Once this has completed remember to do a white load following this procedure to assure that if there is any bleach residual then it wont cause problems with colors.
3. Dry the door seal after each use... this will eliminate mold from developing on the door seal. If you see mold then use a bathroom cleanser for mold removal to clean the seal... DO NOT USE A SOLUTION OF VINEGAR... THIS COULD DRY OUT THE SEAL CAUSING IT TO CRACK THUS REQUIRING REPLACEMENT.
FYI: The Maytag Company went bankrupt sometime ago, the name Maytag wash purchased by Whirlpool and appears on products to secure the business of faithful Maytag users...
Posted on Apr 19, 2014
I have a Maytag Neptune washer model MAH5500BWW which we continue to have several problems with. Yesterday our laundry room flooded due to the failure of the incoming water valve being stuck open so the...
im going to try and help if the burnt out part is the motor control and motor ,,you may can get the parts for free,,they had a recall on some of theses models,,go directly to maytag recall.com /whirlpool recall .com...or service matters.com.....heres the number to there recall department 1 800 462 9267...the motor and motor control comes in a kit...good luck
Sep 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
My whirlpool washer (Model wtw5100sq0) has started leaking when it is NOT running. I read of several things to check. What is the most likely place to start?
you should probably suspect the water valve inside the machine.to check this,close the valves that the supply hoses are connected,spin out any water left in the drum and watch for water by placing a few towels in the drum over nite
Jun 09, 2011 | Whirlpool Washing Machines
Water leaking
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 07, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Are there any recalls on the hp 2840 imaging drums?
I can't recall. LOL No recalls that I know of. I sell toner and drums. But what is really going on with your drum. They work very well. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 2840 All-In-One Printer
Water leaking when machine is off
you need a new water valve. it is located at the back left hand side under the main top(the piece the hot and cold water hoses hook on to)
Feb 08, 2010 | Whirlpool GHW9300 Duet Washer
Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Samsung WF203ANW Front Load Washer
I have a LG wm3988hwa and it pumps cold water into the drum while drying. I have determined that it is not the 5way valve. Any ideas?
I have not looked up your model number, but on LG combo washer/dryers, drying requires addition of some cold water in the vertical vent area to facilitate condensation (and thus moisture removal) from the dryer's air stream. This cold water should then pass under the drum without contacting the clothes. I'd check the pump inlet filter at the front left of the machine, and I'd remove the back of the machine and then the big rubber connector at the lower left side (as viewed from the back of the machine) and remove any lint which may be impeding water flow at that point.
May 24, 2009 | Washing Machines
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
