Question about Maytag Dryers
Maytag 3000 CF1, CF2, CF3 Error
Our Maytag 3000 dryer currently has a code of CF1 on it, when you press a button it cycles through CF1, CF2, CF3. I have tested the Thermal Fuse (Out) and it seems fine. What should I look at next?
    Habit-Forming:
    New Friend:
  • 186 Answers
Look inside your machine, you should find the service manual, it will tell you how to put it through self diagnostics. And your Machine may have several Limit switches that you should check.
Posted on Apr 19, 2014
  • Sean Sowell
    Sean Sowell Apr 26, 2014
    I am unable to get it into diagnostics since it says to hold down a button for 2 seconds and release for 2 seconds and repeat. When I do this it just cycles CF1, CF2, CF3. Also tested the thermastat seems to be ok as well.
  • aaahandy
    aaahandy Apr 28, 2014
    ok did you find the service manual? Cause it will tell what those codes are and how to repair it.
catriver
  • 878 Answers
SOURCE: Thermal switch location
On a series 10, it's located behind the bulk head, behind the drum. On a series 11 they moved it to a bracket on the heater cone. Catriver.
Posted on Jan 01, 2008
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
  • 532 Answers
SOURCE: Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
Posted on May 10, 2009
rtillx4
  • 11 Answers
SOURCE: dryer won't run
I would say that maytag has a problem with lint collection. That is why so many thermal fuses blow and why so many people just bypass this "saftey" device rendering it more dangerous.
I would advise anyone with this model Maytag dryer to pull the front body panel and clean the lint out and then replace the thermal fuse.
Posted on Dec 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Posted on Jan 06, 2010
Testimonial: "Excellent info. Thermal fuse was out of sight. Mention about LA-1053 helped. Honestly, I didn't know how thermal fuse looked like."
I have a Maytag dryer model: MEDE300VW0 that is showing a PF code. I have tried unplugging, pressing the cancel button, etc. as recommended on various internet sites. PF code persists.
i know that the voltage overseas is different form the usa,that's telling you there was a power failure while the dryer was running,check the back of dryer to make sure you have 240 volts going to the dryer,you could have a bad power cord or something to do with power source.
Feb 06, 2018 | Maytag Dryers
Maytag 3000 electric dryer is showing error code cf1, cf2, cf3
you could have a bad control panel,the dryer thinks your pressing the dryness level button in and you're not touching it,you can try unplugging the dryer and rub over the dryness level button and see if it frees up,if not you have to change out the control panel because the button is stuck,when you rub the button it should feel like any other button on the panel
Nov 01, 2017 | Maytag Dryers
Maytag dryer 3000
i have same dryer check fuses it may have 2 fuses on your breaker that'sall my book says
Jan 10, 2014 | Maytag Dryers
I got pf on maytag 3000 dryer how do i fix it?
"pf" means Power Failure took place during the cycle or the cycle was interrupted, It comes when power connection is loose to the machine, Unplug your device for 5-10 MINS, plug it back then press CANCEL button.
Good Luck and have a nice day.
Jul 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Maytag neptune washer will not get up to speed in spin cycle error code E3
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 09, 2010 | Maytag Washing Machines
Screen reads CF1, and does not work
Maytag 3000 series .Dryer screen reads CF1, then CF2... then Cf3 and does not work
Apr 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
F20 error
troubleshooting with the F20code what it says in the trouble shooting section:
Ff20 (water inlet problem, no water or insufficient water supply)
Select stop twice to cancel the cycle. Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer. Re select cycle and press start.
Sep 19, 2009 | Washing Machines
Power Failure
Try unplugging the unit for 5 minutes and let the control panel reset.
Nov 20, 2008 | Maytag Dryers
Dryers Logo
263 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
