TV no sound, picture bleached and skewed
I have an Orion TV that today suddenly turned off by itself. Upon turning the TV back on, it now has no sound. The picture has also been bleached of its colour and skewed towards the bottom right hand corner. Any help would be great. Thanks.
    Master:
  • 687 Answers
Model. serial numbers would be helpful.
Posted on May 08, 2014
SOURCE: Lost all Power to TV
My TV did the same thing today. My red light blinks 6 times. Any help would be much appreciated!
Posted on Jan 06, 2008
  • 6 Answers
SOURCE: plasma wont turn on? only power button will.
The problem is a $1.09 part. You will need a soldering gun, multimeter, etc.. Or someone else who is electronically inclined.
The fix for it is here:
http://www.instructables.com/id/Dell-W5001C-50quot-plasma-fix/
I have the 46" Dell model with the same problem and this fixed it. Part cost $1.09 plus shipping.
I can't take credit for this persons post so post thanks on fix.
Just note, TV's can hold electricity even after being unplugged. So if you try this keep that in mind. You shouldn't mess with it until an hour or so after you unplug it. Or google "discharging capacitors" to discharge the electricity from the power board. Attempt at your own risk.
Posted on Jun 04, 2009
SOURCE: Emerson EWL20D6 TV turns on and the picture goes right back off
Mine is doing the same thing. I talked with a local repair guy over the phone and he says that (obviously) something is malfunctioning in the TV and a sensor shuts it off to minimize the damage to other components. This would be ok if the TV were 20 years old (they used to last that long); however, mine is only 1 1/2 years old and Emerson couldn't give a damn that the TV is a piece of ****. Silly Mimi
Posted on Apr 02, 2009
carlsbiz
  • 1124 Answers
SOURCE: tv keeps switching itself off
When that happens - try unplugging the tv for a few minuets & plug it back in.. Sometimes it will reset its self.. Or it could be a bad sercut or maybe a falty power suply.. Electronics is usually process of illimination - unfortunately..
Posted on Jul 08, 2009
  • 148 Answers
SOURCE: TV will not turn on.
Most likely your powerboard. Inside those are capacitators that are known to "pop". They have been widely used in many newer tv/monitor units since around '97 I believe. Anyway, Some problems with these things are a little harder to figure out, but a problem that shows a light(flashing/blinking/on for while/off for while) is to my new found knowledge a bad capacitor or 2 in your powerboard. I found a 19" lcd monitor that didnt come on, but the power light is on. I bummed then googled it and found this to be a VERY common problem! I watched a video on youtube how to fix your monitor and openend mine. I found 1 bad capacitator(bad caps show a buldging top and/or fluid leaking from them. one trip to Radioshack and $1.59 The problem was fixed! A rapair man woul;d order your board, install it and charge you around $300 or more. You could change your board yourself(saves money) or you could open your unit and inmspect it yourself first, your fix could be $5 or less!....There are many pic etc to be found on google image for "popped" capacitaotrs(caps), also there are video's on how to replace them on youtube...I hope this helps some!
Posted on Feb 01, 2010
Our orion t.v. started doing this this winter....it will all of a sudden lose the picture, the sound is still there but now picture. i can turn it off and a few minutes turn it back on and its there,. then...
Tv turn on,this happen.Make a fist bang on the tv frame,see if tv have a picture come back or have it flashes in and out?Yes,than tv is having cold soldering joints on the video board pins that connections to between video board and the CRT-(tv tube) those joints connections pins on the video board are to make the CRT-(tv tube) to have a picture.U have all the tools like a soldering iron,a roll of solder and also can u do basic soldering work?Yes,take the tv aparts.The video board,that the the board that connected to the CRT-(tv tube).Resodering all the soldering joints connections pins between CRT-(tv tube) and video board should solved this problems.Or tvs shops can do those resoldering for u,by telling them the problems.It should cost u like around $50.
Apr 10, 2011 | Orion Televison & Video
NO SOUND
Unplug,replug the tv about an hour later,let the tv reset itself back to factory setting.Go in the tv menu go to AUDIO.Go down to reset let the sound function in the Tuner baord reset itself to the correct setting.From now on ur tv should not lost suond, when turn tv off and turn tv on anymore.
May 06, 2010 | Panasonic TC-P50X1 50 in. Plasma HDTV
We have an orion 2501B TV.no vertical display
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Jun 30, 2009 | Orion Televison & Video
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
Sony LCD 52 inch
This sound like you are having problems with the power supply board. Since you are getting a momentary picture and sound the fuses are good but TVs today have "shorts" and "overvoltage" circuitry build in that will shut it down on errors. Someone knowledgeable in electronics will have to isolate the exact cause.
Dec 05, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Turns itself off
screen control. pict to bright. normal to shut down. when this happens. ****** screen control.
Nov 19, 2008 | Zenith B25A10Z 25" TV
Won't turn on
my orion tv is not working,it just stopped
Apr 29, 2008 | Televison & Video
My T.V is turning itself off after 2 seconds where you can hear sound but there is no picture
Hello according to the symtom that you have describe I think that maybe you have activated the sleep function button on your tv and if this is not so maybe there is an internal problem on the main board of the tv.
Jan 10, 2007 | Sylvania 6413TD 13" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
