Question about Frigidaire Kitchen Ranges
ERROR FF20 AND FF5
My range has stopped working, if I leave it unplugged over night its good for about an hour. Then everything shuts down and I get the errors flasing f20 in the center display. f5 on 2 on the element displays. The other 2 elements display 00
  • Official Brand Answer
  • 2,267 Answers
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Posted on Apr 21, 2014
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
SOURCE: Kenmore electric range
You need a new mother-board.
I had the same issue, it overheated my kitchen in a matter of minutes. If I didn't turn off the circuit-breaker, I probably would have had a fire - the heat being emitted was intense. The cost is running around $300. with tax and delivery. I'm not sure if I want to repair or purchase a new oven.
Posted on Sep 25, 2008
Treefrog15
  • 127 Answers
SOURCE: ERROR CODE # F6E1 displays and shuts down oven
F6-E1 - Return Line Not Connected - Replace control board (clock).
Posted on Dec 23, 2008
cactus bob
  • 267 Answers
SOURCE: I have a Sears bought
the burner must be replaced . easy job, open oven look under lip of stovetop there are two 1/4 inch drive nuts , remove them then you can lift the cooktop you will see the underside of the burner . its held in with two screws , carefull of the clips,there easy to loose . let the old burner hang by its wires . when you get the new one in move the wires one by one to the new burner ... you will need two people one to hold the top up and one to do the work . dont forget to turn power off to stove . part will cost around 100.00 should take no longer than 15 mins to do the job . have fun and good luck ........ please rate this answer i need votes to stay here , thanks
Posted on Feb 01, 2009
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
replaced bottom element in oven , now neither element works ?
Posted on Jun 15, 2013
Panasonic viera 50" plasma TH-50PZ85X shuts off after 2 hours
No error code is being triggered, If you are using a box do not forget when you remove power to the TV also remove power for box and set at same time, other than that may be a main board issue.
Me I would to rule crazy things out disconnect everything going to the set except a DVD player and sit back and see when it fails, I am just wondering if something coming in is not triggering this, these sets have pretty good detection and if shut down show a error most of time.
Not sure if any of this will help but felt you deserved some thoughts at least.
Dec 11, 2012 | Televison & Video
Hello, I was using the self-clean function of a Kenmore Rangr 790. It first showed an error code the it showed F30 and now it shows F10 error. It keeps beeping and won't shut off beeping. Do I need to...
Try turning it off at the breaker. It is way easier than pulling it out and unplugging it. Also, leave it powered off for at least 7 to 10 minutes. This sometimes resets the control board and stops the beeping. If the beeping starts up again you may need a new control board. At this point it is a good idea to call in a pro. Good Luck
Mar 14, 2011 | Kenmore 46702 / 46704 / 46709 Electric...
I accidently left the freezer compartment partially open over night. Everything melted. Now that the door is properly shut it seems like it is not getting cold. How long would it take for the freezer to...
If the freezer empty it might take an hour. If there is product in the freezer it will take longer depending on how much is in there. If it does not cool down. Your evaporator coil may be iced up from trying to cool the freezer all night. To fix this problem just unplug the box and remove all the items from the freezer and leave the door open for a few hours to defrost the the coil. After this everything should be fine. I hope this helps you. Please leave feedback. Thank you.
Aug 24, 2010 | Samsung RS2534 Side by Side Refrigerator
F20 error
troubleshooting with the F20code what it says in the trouble shooting section:
Ff20 (water inlet problem, no water or insufficient water supply)
Select stop twice to cancel the cycle. Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer. Re select cycle and press start.
Sep 19, 2009 | Washing Machines
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Range JGBS 23...The Broiler does not shut off
the switched has malfunctioned. you must unplug the stove to turn it off do not leave it on be very carefull unplugging it do not touch the prongs its 220 volts?
Jun 20, 2009 | GE JGBS23 Gas Kitchen Range
Kitcheaid electrical Oven
If you go to repairclinic.com click on repair help at the top then "error codes" on the left side in a gray box. you can look up the error code. I found F2-E0 but not FE02 for a KitchenAid range.
What I found means shorted key pad. Some times just unplugging the unit or shutting down the circuit breaker that controls it for half an hour it will reset. not guarunteed but less expensive than replacing if it works. Good luck.
Jan 09, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Off button doesen't shut off oven
You will probably have to replace the electronic range control.
Jan 03, 2009 | KitchenAid KESC307 Electric Kitchen Range
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven or smooth top will not turn on. breakers are good and it is plugged in.
Unplug the range. Wait a few minutes, then plug the unit back in.  Reset the clock per your user manual. A pdf copy of your manual may be available on line at the Magic Chef site or the Maytag site, since Maytag has or had a similar model.
Dec 04, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
138 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
