Question about RCA Televison & Video
Dpdm90r weak or no signal with antenna plugged in, no tv signal
5 Suggested Answers
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
ripleymojica
  • 643 Answers
SOURCE: Polaroid TV with
tuner is bad. they dont make spare parts for that tv.
Posted on Jul 06, 2009
  • 156 Answers
SOURCE: I have tried two different antennas and the screen
If you're using an indoor antenna (rabbit ears), you'll find that there's little difference between them. Yes, you'll see all the fancy knobs, but mostly all they do is delay the signal from making it to your antenna jack, hopefully enough to reduce ghosting on analog channels...or a resistor circuit that reduces the signal strength. Receiving a good signal with an indoor antenna can be difficult...there can be obstacles between your tv and the broadcasting station, you could be too far away...it's hard to tell. Before you use an outdoor antenna (consider a good RV antenna if you need to use it indoors), try an antenna amplifier. It'll have to handle both VHF (at one time channels 2-13) and UHF (channels 14-69 analog). If it's an "antenna amplifier," it will be sufficient. If it's a cable amp, it would be a hit-or miss. The amp may be able to boost your signal with the indoor antenna you have now. Alternately, you can buy an indoor antenna with the amp built in. Hope this helps.
Posted on Jan 28, 2010
  • 586 Answers
SOURCE: Just bought a house and
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
Elect_Comp.
Posted on May 12, 2011
My tv screen is snowy and I get the prompt: weak or no signal...check the antenna cable connection (I have done that) and run auto program ( have done that).
all channels? outdoor antenna? if indoor antenna try moving antenna around to find the best spot, also you need to know from which direction your signal is coming from and how far you're from tv station, if too far you may need a signal booster, and make sure your antenna is for digital signals. same goes for outdoor antennas.
Jan 30, 2018 | Televison & Video
What causes pixelation only on digital 9 TV and there subsidiaries
Pixellation is a weak and noisy signal coming in. Digital HD needs a good signal at the antenna socket on the back of the TV. You need to have good quality quad shield coax cable down from the antenna, and preferably crimped F-connectors at each plug and socket. You may even need a new digital antenna if you are making do with an older analogue one.
Your other stations will also improve.
Dec 26, 2015 | Televison & Video
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
Unable to set TV channels on Samsung LED TV
Check the orientation of the antenna. If the transmitter you're trying to tune is very far away from your home, the signals will be very weak, that the tuner inside the TV can't catch. If this is the case, the orientation of the antenna is very important.
Dec 03, 2013 | Samsung Televison & Video
Hi, ihave a plasma TV, sometime ago and it has only been since we moved houses, our TV goes pixelated and then we get No signal on 1-2 channels, and now we have no signal full stop, i have a booster...
You have antenna issues. Try raising the antenna some more or relocating to another spot where the signal strength is greater. Pixelation is a sign of a weak signal -
Jul 02, 2017 | LG 42PC3RA 42 in. HD-Ready Plasma TV
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Yours sincerely.
Elect_Comp.
May 12, 2011 | Televison & Video
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Yah i have a dynex tv and a Asus desktop comp and my tv says no signal when i plug it in i dont know what the problem is
Is the dynex tv unit installed inside the ASUS desktop computer?
The TV receiver needs an antenna/aerial connected to the TV receiver to receive TV signals, without it you will get no or weak signal.
Have you connected an antenna/aerial to the Dynex TV unit?
Jul 22, 2009 | ASUS Computers & Internet
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
