Question about Cameras
Hi I have a Minolta 58mm 1.2 lens the later version with the waffley focus ring it had loose parts on the rear and there is a tiny spring the is attached to the underside of a black ring by a small screw the black ring has a inside facing rod. Where does the other end of that spring go ? there is another smaller spring that is attached to two posts but this in the one on the outer side. Assembly diagrams to re-assemble the last few components of the mount would be great. kevin
  • kandjkburton Jun 19, 2009
    Hi, the re-assemble is only relevant if you have the mount assembled I have not....
    All the mount components are seperate all eight screws are out and it's all in bits.
    There are only two springs one is attached at both ends one has dropped off.
    A re-assembly diagram/instructions would help to put these back together.. not
    interested in the AF or digital mount conversion, but thanks so far. Kevin
    Photos of the lens assembly found for me after I had searched hi and low. Great service id you need it fast... heres where to find it. Minolta4me
  • 315 Answers
Guide to converting the legendary Minolta Rokkor PG 58mm f/1.2
1) Introduction
Hi I have a Minolta - 3125240759_742f894012.jpgThe Minolta MC/MD register distance is about 43.72mm, whereas the Pentax one is 45.46mm. The difference between them is about 1.74mm.
Required things:
- A M42-PK adapter (~7$)
- Some screwdrivers with small diameter.
- A drilling machine with 2 drills: 2mm and 3mm.
- A file.
2)Disassembling the mount
There are 8 screws, we need to unscrew the 4 long ones, because the 4 short ones hold the diaphragm actuator with the mount.
File off the ridge around the outside of the aperture ring.
imgp3886.jpgIn this above photo, the ridge were cut off.
Continue to unscrew the 4 screws of black ring.
Rotate the aluminum ring in counterclockwise direction. Because we don't need the mount spacer which have a thickness 4mm. Therefore we must adjust 4 - 1.74 = 2.26mm in height by rotatingHi I have a Minolta - imgp3888.jpgbr />
3)Reassembling the new mount:
After rotating, we re-screw the black ring.
Drill the 4 holHi I have a Minolta - imgp3891.jpgely on the M42-PK adapter.
imgp3891.jpgNote that: the red dot on the adapter will the same position with the diamond shape
Place the aperture ring in its position with the ball ring. Beware of the ball ring. It is very small, Do not lost it.
Re-screw 4 long screws on the new PK mHi I have a Minolta - imgp3899.jpgbr />Voilà, the conversion is done.
We can do the same way with Minolta Rokkor-X 50mm f/1.2. This is the later version with MD mount. This lens hHi I have a Minolta - imgp3904.jpgpacer mount, therefore we must file the lens cover as the image.
I converted the Kiron 28mm f/2 as the same way of the Rokkor-X 50mm. Its focal length is smaller, so it needed to file more precisely in order to focus to the infinity.
Posted on Jun 19, 2009
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
I have several old,some very old cameras which have due to obviously wrong storage developed fungus inside the lenses. I am a retired engineer, but do not know how to remove the lens front without doing...
This is a tricky job- you have to be able to reassemble not just the lens components but the aperture diaphragm and focusing components. There are lots of little springs that jump out and sometimes tiny loose ball bearings.
But if you feel confident- most front lens elements are held in by a retaining ring that can be unscrewed. On older lenses this is obvious, with a couple of slots in the retaining ring, one one each side. You need some kind of tool to engage these slots without slipping and scratching the glass. I have actually used the points of the blades on a pair of scissors, but this is obviously not to be recommended.
On later lenses, there may appear to be no slots. Usually this means that the actual retaining ring is hidden behind a dummy. If that is the case, and there is no way to be sure but to try, you can unscrew the dummy ring by using friction, with a disk of rubber cut from an old innertube pressed against it, or maybe a rubber glove. This ring does not have to be screwed up very tight, as it is only cosmetic. Sometimes this ring is the outer surface of the front end of the lens housing, and sometimes it is an insert.
Sometimes it is easier to get at the inner surface of the front element by disassembling the lens from the rear, which is usually a matter of removing a lot of tiny screws.
However you get in, you are likely to find that removing the the mold does not clean the lens completely. It will have etched faint lines into the lens coating, and you will also introduce a certain amount of dust, which I have never managed to eliminate entirely.
Oct 20, 2010 | Canon Cameras
Broken rear lens element on Nikkor Noct 58mm 1:1.2 lens
I recommend to call Barry Edmonds Nikon technician at Fixation UK LTD
44 20 7091 2550
All Best
Rafal
Jun 16, 2010 | Nikon Cameras
Minolta Standard Zoom 7x to 15x x35 binoculars
yes it is fixable its the inner lenses coming loos and they will need to be fully striped down and cleaned the body air blasted out and then all lubed and put back together before being re-gased,,,standerd overhall job,,,pricy too,,,
Mar 03, 2010 | Optics
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Focusing problem
Hi everyone.
I had the same problem with my 400D. It refused to focus. On manual focus I could take pictures though, but not on Auto focus.
What happened was I cleaned the mirror with a piece of soft cloth, the spring hooked onto the cloth and came loose.
I took my lens off, checked the mirror, found that the little spring connecting the mirror and the little glass part above the mirror was loose. Took a lot of patience and hours to get it back in. I used a pair of tweezers 2 x toothpicks and a short piece of fishing line (thin line). Go have a look at another 400D how the spring should be clipped in. I used the fishing line to hook the " L " shape of the spring back in after I lined the back part of spring up, since there is no space next to the mirror and the body of the camera.
Like I said. This takes a lot of patience and be prepared to sit for 3 to 4 hours.
It worked though.
Hope this helps.
Where can I get a service manual for the 400D ?
Jul 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Minolta digital camera,s
Simple answer...Take your best working lens to a camera store,and ask to test a sony a100 digital camera. ALL Minolta Maxuum auto focus lenses work with the a100. This includes Konica/minolta type also. If you don't have an auto focus lens, it still might work-but you would loose some features, by swaping camera bodies. In the least it would cost you nothing to find out what camera they would work on, and save you enough money to partly pay for the new camera body you want anyway. Shoot a few stills with your lens on the different bodies-after all your not waisting film-until you find one that is good for you. The camera shop might even have an adapter ring for your lens to the camera body of your choice.
Jun 11, 2008 | Konica Minolta Cameras
How do I use the Minolta 2.8 100 mm lens ? Sothat I can choose the image ratio and focus on a 7D Minolta Dslr
well is it a analogue lens designed for 35mm film camera's of minolta ? Most of the time wenn using a non -cpu lens on a dslr body yuo have to lock the apature to the highest count (for example F 22 ) otherwhise thae camera will or might refuse to operate. if the lens is not to old you can try if the camera will outo focus if not you have to set the Autofocus to Manual Focus and lock on the target by turning the focus ring
Devlious greetingsz
May 31, 2008 | Cameras
Canon EFS17-85 mm Image Stabilizer Lens stuck in Macro mode.
The USM focus works by applying pressure to a set of rollers. That pressure is achieved with a large diameter spring washer. It is held in place by another large diameter flat washer that on assembly is rotated 60 degrees to lock it in place. If the lock washer has moved due to mechanical movement (ie rapid manual movement of the focus ring) it could unlock and then all pressure to the USM motor parts and rollers is lost giving the loose feel you mentioned.
You will need to dissassemble the rear of the lens to see the USM motor parts, rollers and locking ring to reattach it. Follow the links at my pbase gallery to see the dissasembly. When I took my lens apart the focus and USM motor went all loose and I wondered how could it work ever!!!. The locking ring was off which sounds just like your fault. http://www.pbase.com/barry_2718/efs1785mm I also have a flex cable cracked which is a much harder fix. Take careful note of the parts (mark then with a felt marking carefully) to achieve a reassembly exactly as removed.
Apr 05, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Camera attaching to telescope
Orion sells the camera T-RING and lens adapter-- and any other focuser parts you need-- look around their site and then call them.
http://www.telescope.com/
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Mar 29, 2008 | Tasco Luminova 40114675 (675 x 114mm)...
Cameras Logo
41 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
