Question about Morphy Richards 48268 Bread Machine
Will not work
When we try to turn maker on its beeps error hhh means to hot but its still cold
HHH code, NOT a second loaf.
1- DELAY TIMER HAS A SWITCH FUNCTION THAT HAS FAILED. 2- WASH INSIDE OF BREAD MAKER WITH COLD WATER, DRY, AND TRY TO SET TIMER. 3- BREAD MAKERS ARE NOT AS POPULAR AS THEY USE TO BE, AND ARE AVAILABLE AT USED ITEM STORES FOR 15 TO 25 DOLLARS.
May 03, 2012 | Sunbeam 5891 Bread Maker
Getting an error reading of HHH and cannot get to menu function. How do I solve this
That is a temperature warning that is an automatic feature on bread machines. What the machine is telling you is that the oven chamber is still too hot from baking the last loaf. It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast. If you want to bake more than one loaf push the STOP button till it beeps, unplug the machine, raise the lid, and leave it open for no less than 20 minutes. It should work fine by then if not let cool off another 10 minutes. It will be cool enough by ½ an hour to start another one.
Jul 26, 2011 | Panasonic SD-YD205 Bread Maker
HHH shows in the window. Won't start. What is the problem
The error code for HHH usually means it is too hot, if it is has been used recently. If it has, unplug the machine, and try to wait for it to cool down with the lid open for about 15-20 minutes. If that is not the case, I would suggest you to contact the manufacturer at:
https://secure.sunbeam.ca/ContactUs.aspx
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Sunbeam 5891 Bread Maker
When the bread is finished baking, after I take the bread out, the machine starts to beep with HHH error, I pull the plug, then when I put the plug back in it shows the time, or menu. It won't shut...
Before you take the bread out push the "stop" button until it beeps in a couple of seconds. Then unplug the machine, then take the bread out last.
Apr 28, 2011 | Cuisinart CBK-200 Bread Maker
The display panel is displaying HHH and won't let me select anything.
Those kind of warnings usually mean the oven is too hot to start a new loaf. Have you just baked a loaf and are trying to bake another too soon?
Dec 11, 2010 | Magic Chef CBM310 Bread Maker
My maker is flashing hhh, what's up?
I don't have your manual but often these kind of alerts mean the chamber is either too hot or too cold to begin baking. If you have been baking you need to let your machine cool off with the lid open for about half and hour before starting another loaf...
Nov 13, 2010 | Black & Decker B2250 Bread Machine
Used 2 times in a row, but now get HHH when trying to restart
That just means that your the oven chamber is too hot from the last loaf you baked in it. It does that because the ingredients have to be at at the correct starting temperature or you won't get a good rise. It's designed to do that.
However, ifIf you have let your machine cool off (open the lid and leave it open after baking for about half an hour) and still shows the HHH then you have a more serious problem and should call or contact Sunbeam.
Nov 09, 2010 | Sunbeam 5891 Bread Maker
What does code HHH mean?
That's a troubleshooting code listed in the manual. It means something is broken and you should take it to a service center for repair.
Dec 06, 2009 | Cuisinart CBK-200 Bread Maker
HHH Error Code
Generally, an HHH error code means the machine is sitll too hot from making the previous loaf. Keep the door open for a bit and allow it to cool down.
Dec 25, 2008 | Sunbeam 5891 Bread Maker
Chefmate HB-215
My book doesn't have an error message E-07, only E-01 and E-02. Both error messages will beep.
E-01 means baking area too hot. To reset open lid and remove bread case to cool. After panel message disappears replace bread case and press start.
E-02 means baking area too cold. Unplug unit and allow it and the baking area to warm. Then try again.
Hope this helps.
Oct 12, 2008 | Chefmate TR 7000 Bread Maker
Morphy Richards 48268 Bread Machine Logo
37 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
