SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
SOURCE: I HAVE KYOCERA KM-1620 MY PROBLEM IS WHEN I
Check that you do not have toner save mode (Eco mode)turned on.Also very damp paper can give this result.
SOURCE: C-6 ( 400 )
KEY IN 1087 TWICE N PRESS START, ENTER CODE ERROR EG.400 N PRESS START. ONCE IT SHOWS CLE, ENTER 163 N PRESS START. WAIT FOR IT TO RESTARST. LALI.
SOURCE: photocopies displays and error message that reads 400 then C-6
It most likely can be reset over the phone. Go to www.gfbm.net and call. They can walk you thru reset over phone whach should correct the problem at no charge.
SOURCE: error C-0150 back up memory of kyocera KM-3540
http://www.eserviceinfo.com/downloadsm/15534/kyocera_km1620/2020.html
http://www.fixdevice.com/smanuals/file/34223.html
Repair manual above.
http://www.fixdevice.com/smanuals/file/34229.html
You mention two, KM-1505 & KM-3540 here is the generic manuals for both.
www.feedroller.com/Store/Service%20Manual/KM_1505P.PDF
Service manual above this is the fix manual above.
Backup memory read/write problem
(engine PCB)
• Read and write data does not match.
Defective engine
PCB.
You have a bad board in the printer it must be replaced.
