KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Posted on Nov 02, 2007
Kitchenaid superba side by side Refrigerator
There is water underneath my refrigerator. I took the front panel off the bottom and found a black pan filled with slimy water. It was full, so whenever the door opens and closes, water spills. The pan is only attached on one side. I'm not sure if it broke off, or if it is supposed to be that way. Should I just clean it out? or do I need to call a repairman?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 03, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1955
Points
8
Take it out, wash it, and replace so that it fits
where it was intended and level. use a flashlight
Is your frig level?
there should be no splashing when a door is opened.
"The pan is only attached on one side"
this cannot be the pan must be level and secure.
We have water underneath our freezer and inside on the bottom shelf
You probably have a clogged drain line. Look for a drip pan at the bottom of the fridge; it should have a hose that drains into it. Thaw out the fridge like you did before, but this time use an air compressor, bicycle pump, or whatever and try to force air back up that hose to clear the clog.
My refrigerator water dispenser leaks water in the water pan. The unit is about 10 year old. It just started leaking.How do I stop it from leaking?
If your water filter is located behind the grille at the bottom of the refrigerator the O ring seal is leaking. Happened to me. Get a new one.
How can i replace the water tube from a kitchenaid side by side refrigerator when the filter broke from the bottom
the filter housing is held by screws from the front and can be pulled from the front but you need to disconnect the water lines to pull it through
Every few days we have water under out fridge / ice making fridge took pannel off bottum of fridge in front there is small pan in there full of water why should this be doing that
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
2helpful
The drip pan that sits under the freezer side of our Kitchenaid Superba side by side refrigerator is full of nasty looking black water that I wanted to clean out but I can't figure out how to get it out of...
well to take that out ? which isn't normal part of it the drip pan catches water from the fridge / freezer and is caught in the pan while the evaporator generates heat to dry the pan out!! so if you really must remove it then you have to remove the wire in front of it to get it out other wise you just unplug it and reach in there with a brush to clean it
9helpful
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
1helpful
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
2answers
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
2answers
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
2helpful
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
