Question about Boating
Trigger pull is bad - Boating
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
How do u get trigger assembly out
Before you remove the trigger, try lubricating all the parts in the head with white grease. If the trigger valve was bad, it would be leaking air as soon as you connect the air supply. Most likely just lack of lubrication or worn parts in the head causing problem. Good luck.
Jan 26, 2014 | Stanley Air Tools & Compressors
I have a pasload im 250 ii straight finish nailer when I pull the trigger the motor runs with out the tip being pressed is this normal and when I press the tip and pull the trigger it does not fire
Yes, it is normal for the fan to run when the trigger is pulled. Does the fan start when you depress the nose?
If not, it most likely is a bent contact element, or a bad head switch.
Aug 19, 2013 | Omega Paslode 901000 Impulse Cordless...
Hello, I have a Hobart 180 and the wire feeder motor won't run. I replaced the wire feed motor and it still won't run. any ideas?
Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
Jun 27, 2011 | Hobart Welding Tools
Does not start when trigger is pulled; is there a reset somewhere that I can' find
trigger switch is probably bad or wire has broken or come lose,obtain parts list from sears to change trigger switch,or see if it is still under warranty.
Jun 12, 2011 | Craftsman 3 x 21" Variable Speed Belt...
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
Relay clicks, but wire feed motor wont operate
check for power to drive motor,if power is there when you pull gun trigger then motor is bad.if no power look for bad wire connections then relay.
May 09, 2009 | Welding Tools
Boating Logo
43 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
