Question about Dometic Refrigerators
Have a dometic rv rm2510 fridge and does not work on electric, starts and cools then quits,works fine on propane and fridge is only 3 years old,been used about 10 times, last year replaced the burner,any info please
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
  • 332 Answers
SOURCE: last year my dometic rv fridge would run fine on
Here is an interesting possible problem to look in to
First a bit of background on LP gas
Your LP system operates on 1/2 lb of pressure Not much more than a breath of air. Keep this in mind for a minute.
A lot of RV's have been built over the years using rubber hoses to connect LP gas to water heaters, furnaces, and refers.
Over time rubber and LP gas create an oil, if you have a low spot in your rubber line that oil will collect in the low spot - - Remember the 1/2# of pressure from earlier? Does not take a lot of oil build up to over power the 1/2 # of pressure and now you are not getting LP gas to your refer.
This is one possibility. The lines will need to be removed from the refer and other low setting items like the water heater and furnace also from the LP tank regulator and the using NO MORE THAN 10 pounds of air pressure blown out. BE VERY CAREFUL this oil is some really nasty stuff - cover the ends of the lines with a cloth in a plastic bag with some holes poked in the bag and rubber band it on.
But first lets look at some other options
Your refer has to have 12 volt power to it to operate
90+ % of all 12 volt issues are grounding problems.
Make sure you have at least 12 to 13 volts to the refer and that you have a good ground.
Next Are you getting gas flow to the burner?
If you are getting gas try changing your thermocouple They run a couple of buck and is an easy test.
If you have 12 volt power and gas have you noticed an ammoina smell?
This model has been known to lose the cooling unit
Hope this helps
Coyote
Posted on Mar 31, 2010
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
  • 3 Answers
SOURCE: I have a Dometic 2193 3 way fridge. It works
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Posted on Jul 28, 2010
DOMETIC RV FREEZER WORKS FINE ON PROPANE BUT THE FRIDGE DOES NOT COOL
Give Arcticold a call. We will help diagnose the problem free of charge. I would help on this site but will require a lot more info. Toll free 1-888-782-6665 I have attached a video that may help. 88bf4c61-06e7-40b5-9515-34afd5643a3d.jpg Store
Mar 28, 2014 | Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
My dometic rv refridgerator is not cooling at all on propane or electric?
disconnect thermistor let run if ok replace if not replace board
Dec 23, 2012 | Dometic Refrigerators
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Apr 27, 2010 | Dometic RM2620 Refrigerator
Does my old propane fridge have a element ?
Propane refrigerators have a gas burner to create the heat for refrigerant circulation. Some propane refrigerators that were used mostly in RV's also had an electric heat element that ran off a power cord or 12 volt battery.
To determine this look at the back of the refrigerator, you will see a gas line that ends in a burner on the lower left side (looking from the back). Just above that about 4 inches will be wires coming out of the box if an electric heat element is used.
Apr 18, 2010 | Dometic NDR 1062 Refrigerator
Have dometic propane fridge in rv and works fine when flat but no
well if you find one let me know???
if it only works when upright start carrying some jacks with you then if its leaning over jack that side up a bit till its flat!
Oct 23, 2009 | Refrigerators
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
656 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
