Question about Plumbing
Florabest submersible pump cracking open
I have a florabest FST1100 A1 immersion pump into which water has leaked. I would like to open up the housing to the electric motor to dry it out but do not know how to split the inner casing apart. Does it unscrew or are the 2 parts a force fit? Can anyone help?
  • 523 Answers
SOURCE: I am replacing my well pump/motor and need the
This attachment should answer any questions you may have on the electrical connections
http://www.franklin-electric.com/business/WaterSystems/service/AIM/default.aspx
Tom
Posted on Oct 03, 2009
heatman101
  • 43501 Answers
SOURCE: some submersible pumps have a gray motor box to
The difference in the two pumps is that with a three wire pump the start and run capacitors are in the gray box. With a two wire pump the caps. are built into the motor. Because of this with a two wire pump you only need to run the 240v down the well to the pump. The yellow wire on the three wire pumps is the igh voltage wire that come from the start cap. I have used both pums but usually use the two wire because they are easier to hookup and the wire is cheaper because you only need to run three wires. (2 hots and ground) On large HP pumps you will always have three wire motors because the caps. get too big to get them in the motor. It is best to go three phase with big pump if you can.
Posted on Nov 14, 2009
john224
  • 1378 Answers
SOURCE: We had a very hard freeze for this area and it
You can special order the part from a local Home Depot or you can get them online. We have used this site (pump agents) before and they where great to deal with.
Posted on Jan 12, 2010
  • 553 Answers
SOURCE: Onga Pump FM .450 switching on and off although no
I'm afraid I don't have enough information to answer your question but this link should help you to solve the problem. http://www.inspectapedia.com/water/watertank.htm
Posted on Mar 28, 2010
Testimonial: "Thank you for taking the trouble appreciated. regards Michael Meechan"
john224
  • 1378 Answers
SOURCE: Cracked housing on a 1 1/2 hp water ace pump.Model
Thank you for posting your question here on Fixya.com.
Water Ace sells direct to the public. Call them at (800) 942-3343 for parts.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 24, 2010
How long can I run the 1/4 hp submersible sump pump
for as long as it is immersed in fluid
when the fluid runs out and it starts pumping air , then the pump seal will fail inside minutes
there should be a float switch in the circuit to prevent that from happening
Nov 12, 2017 | HP Electrical Supplies
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
Florabest submersible pump FST 1100 A1
That pump is sealed and not normal opened by the user. If you do not assemble it correctly it will become a shock hazard.
Apr 19, 2014 | HP Tools & Hardware - Others
Pump continuosly runs after water is cleared out of basin
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Mar 24, 2014 | Hydromatic Pump Hydromatic V-A1...
go to the local tools shop and this blade will be in a collection of assorted blades that you need to remove a variety of screws.. Most use a special screw driver handle (in the assortment) or a small socket that fits the shaft.
Jan 03, 2014 | Tools & Hardware - Others
I am getting oil out of the pump. Can this be a leak of coolant and can it be fixed.
I am sorry to hear your getting oil, this is not a good thing. If you remove the pump from water and disconnect it from any power source, try removing the lower housing and take a look around the impeller if you can. If the leak is coming from around the edge of the main housing your in luck, it is probably the main seal that can be replaced without too much trouble. If the housing is cracked or leaking near the bearing I am sorry to say it would be best to start looking for a replacement pump.
Mar 08, 2011 | Simer 1/6 Hp Submersible Utility Pump
Submersible sump pump leaking oil. are repair parts available. Pump is Teel 1p914
If it is leaking oil then the case is cracked and it would be as mush to fix it as to replace it.
If it is fairly new the take it back for a replacement if not you can get parts but the case is not one of them.
The problem is that if oil is getting out water is getting in and the pump will fail very soon.
Mar 01, 2011 | Plumbing
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
