Question about Dewalt Dc012 Worksite Radio With Built-In Charger
Radio will not work on AC
Radio won't work on AC. But will work on the battery
    Master:
  • Dewalt Master
  • 996 Answers
Check ac wire & its connecting jack,then step down transformer
Posted on Dec 22, 2014
Odometer won't work unless headlights turned off, radio lights dim, blinker won't blink all the time now battery light comes on but battery tests good. Intermittent issues getting worse. Horn
You probably have a bad ground in the electronic instrument cluster, or cluster connection to wiring harness. I would recomend you have a qualified auto tech diagnose it. It is not a easy fix.
Mar 16, 2013 | 2000 Ford Expedition
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Won't power on
Have you tried plutting it in directly to the power source with out the battery? If this works, it may be that the battery is dead, you can try to jump it by putting the battery in after it has already been turned on. Or just replace the battery:
http://www.tss-radio.com/products/replacement-battery-for-pioneer-inno-and-samsung-helix-xm-radios
If it does not power on, it could be the power cord is bad:
http://www.tss-radio.com/products/xm-5v-home-ac-power-adapter
Otherwise, the unit itself may just be dead.
Jun 26, 2012 | Pioneer GEX-INNO1 XM Radio Receiver with...
I have the Sony S2 Sports ZS X1 and it will not turn on.
Before confirm transformer fault, load batteries and see whether it works. After loading batteries, pull out its AC cord from its AC socket at it back side. With AC cord connected at the back of the set, battery supply won't connected to the set. There is a cut - off switch at the AC socket. Only after removing the AC cord, the set will work on battery.
Try this. If it works with battery, make sure that transformer or internal mains fuse has blown out.
May 29, 2012 | Sony S2 Sports ZS-X1 Radio/CD Boombox
My ac quit working (won't even blow), windows won't go up or down and radio wont work only will eject
Hi Kolya, Check around for a loose or broken cable especially around the battery connections. Regards John
Apr 23, 2012 | 1995 Chevrolet Suburban
The car won't start; lights, ac, radio etc come on but car won't turn over or even click; checked battery cables; put different battery in; still won't start
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
Jun 12, 2011 | 2001 Ford Escort ZX2
Works on batteries. does not work on ac. If you leave cord in it and turn off ac it still will not work, but if you take cord out of the unit it will then work on batteries.
If the AC cord can be removed from the back of the radio, then there is a mechanical lever inside where the AC cord plugs into the radio. That lever will cause the battery connection inside to be open (or disconnected) so that it will run off AC and not blow up the batteries. That is why it won't run on batteries when that cord is plugged in.
If it runs on batteries but not AC, find another cord to try. Most radios use about the same cord. If a second cord still doesn't make it work, it's most likely a fuse inside for the AC circuitry. they are usually mounted on a circuit board inside the radio right near where the AC cord plugs into the radio.
You should be able to take the radio apart (while it's unplugged from AC of'course) and find that fuse. If your good with a soldering iron you can replace the fuse. Replacements can be found at Radio Shack. If your reading these instructions to begin with, your probably not good with a soldering iron and you should just buy a new radio. Good luck.
Nov 26, 2009 | Durabrand CD Player with Cassette...
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Dewalt Dc012 Worksite Radio With Built-In Charger Logo
102 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
