Question about MSI Computers & Internet
NO SIGNAL TO MONITOR,KEYBOARD,MOUSE ON STARTUP
MED MT 515
    Brigadier General:
  • MSI Master
  • 3,400 Answers
DETAILS.
Posted on Apr 20, 2014
3 Suggested Answers
mgdev24
  • 59 Answers
SOURCE: replaced motherboard, no signal on monitor
IF THE COMMUNICATION PORT FOR YOUR DEVICE IS NOT UNBOARD THAT IS IF THE KEYBOARD, MOUSE AND YOUR VGA CARD ARE THE REPLACEABLE ONE, TRY TO CHANGE THOSE CARDS THEY MIGHT NOT OK ANY MORE. IF YOU STILL HAVE SAME PROBLEM THEN THE MAINBOARD IS NOT OK, ALSO, YOU CAN CHECK YOU MEMMORY CARD THAT IS RAM IF YOU DON'T ATTACH IT PROPERLY IS CAN CAUSE THE PC NOT TO BOOT. IF IS RAM FAULT YOU WILL BE HEARING SOUND FROM YOUR BOARD, ATTACH IT PROPERLY.
Posted on Nov 19, 2008
bronk50
  • 27725 Answers
SOURCE: no signal monitor and keyboard
desktop or laptop computer ?
if it a desktop
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines or a can of compressed air.
dust causes static which causes lots of problems with a computer and its parts
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the batteries are fully charged and have good seating points (if applicable) corrosion
make sure the ps2 lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Posted on Sep 01, 2012
How do I reconnect the keyboard connection to my Medion PC MT7? It has become disconnected.
Upgrade the keyboard.
Change it for a USB type, the boot up software should recognise it without any problems
Sep 30, 2014 | Medion Computers & Internet
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Pc: MEDION MT 7. Type: MED MT 343. 440801
go to device manager, and look for the audio device, see the properties, and uninstall the dirver corrupted and installe the driver update. Of course you must download previously from your supplier computer for free , go and download.
God bless you
May 31, 2013 | Computers & Internet
MEDION MT 7 boots but no signal after a fall
please download the driver update from your computer supplier. then go to device manager, search for audio uninstall the driver corrupted and install the new driver update. see the proper when your see the dvice make click, and proceed according.fix it.
God bless you
May 31, 2013 | Medion Computers & Internet
I do not know which driver or suond card driver i need for win xp home edition medion Pc Mt6 MED MT178A ART nr.10002270 MED S/N11120030390002
Step 1:
Download Everest From Here,
Step 2:
Open the file and run Everest.
Step 3:
Goto Multimedia and try to Find your device
Step 4:
Search for these drivers on Google.
If you still don't find them, Download AC97 Drivers from Here.
or Download HD Audio Drivers from Here.
Feb 20, 2013 | Medion Computers & Internet
Mouse, keyboard, nd monitor wont work
U will not damage the hard drive. It was dying from the moment it was created - you just do not know when.
If they work normally with a regular startup I would just forget about the sleep mode.
Aug 24, 2017 | Computers & Internet
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
No keyboard, mouse, or monitor
try to reinstall your memory card
Jun 18, 2009 | E-Machines eMachines Desktop PC
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    Computers & Internet Logo
    59 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    David
    David
    Matthew Spark
    Matthew Spark
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
