Question about Cameras
Button to push for various speeds broke off.
This is one year 3 months old. Now not covered by warranty .Seldom used, very unhappy would never purchase another one of your products. Cost more to send it back than its worth. Paid 21.99 plus tax 24.85. waste of money.
sonyspares
  • 89 Answers
SOURCE: Power button stuck in down position
You may have to change to switch portion and if you need assistance in blow up diagrom or spares, contact me.May take 3 to 4 weeks to get from Sony service.
Posted on Mar 29, 2007
  • 77 Answers
SOURCE: screen is broken, is it worth fixing
It is not worth repairing, the panel would cost as much as a new tv. have it looked at though maybe your warranty tech will slide it through. Probably not but its worth a look.
Posted on May 11, 2007
SOURCE: Lens cover closed
this is easy to fix. in fact, i just did it on my camera about 2 minutes ago and came back to this post because i was originally looking for a solution myself. anyway, you have to be a little bit rough with the camera to fix it. on the outer lens cover you will notice that there is a metal cover on top of the plastic slider. you need to pry the two apart. there is some seriously sticky tape that is holding the metal cover to the plastic, so you need to be careful that you don't rip the whole thing off. once inside you will see a copper contact that (when you slide the lens cover) makes contact with another piece of metal. when i took a look at mine, it was covered in a bunch of lint. i used a q-tip to clean both contacts and then made sure that they were properly aligned. after that, i slid the lens cover back down and voila! works everytime now. use some superglue to put the metal cover back on again.
Posted on Jun 24, 2007
informatica
  • 1114 Answers
SOURCE: waste ink absorber -mp500
Service mode operation procedures 1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons. The COPY LED lights in green to indicate that a function is selectable.) 2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.) 3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in green, starting with Alarm LED.) 4) When the COPY button lights in green, press the Stop/Reset button 4 times. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in green, starting with Alarm LED.) 5) Press the ON/OFF button 2 times. You're good to go! Bear in mind that if the ink absorber is full then you risk getting ink everywhere! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 31, 2007
mcomijohns
  • 477 Answers
SOURCE: Broken battery cover DX6340
I have this camera once you remove the case screws than when ever you seporate the case the door will come out. I repair these all the time and if I have on in stock it is only 25.00 to get it fixed. I beleave you can order one directly from kodak also.
Posted on May 05, 2008
Cracked screen
Depends on the warranty and how it broke. The one year warranty written on the box is from the manufacturer. You may or may not need your receipt. Call/email the manufacturer and ask about the warranty. If the warranty doesn't cover accidents, hopefully the device broke under normal use, and you'll tell support that when you contact them.
Feb 24, 2014 | Tablets & eReaders
NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Dec 15, 2009 | Nordic Track Exercise & Fitness
Same as others plastic door handle mounts broke
This as you know is not an isolated incident with this happening. There are dozens w2ho have had the same experience. Contact your obudsmen in writing about this as it should be covered under Manufacturers warranty. It is a known problem on this item and is not a problem caused by its use or by accident of the purchaseer. It is a faulty item used in m,anufacturere and therefor is covered by a warranty. Put your complaint To the President of SAMSUNG at their Head Office not their support contact. State your experience with the handle, the staff at support and procide the copy of the letter to your Ombudsmen as well as an intention to attempt a class action fro others who have this problem.
Please rate our help++++Thanks for using FIXYA
Sep 28, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
Leica disto A3 button broke
Mike,
Leica does not sell replacement keypads, if the unit is less than 2 years old they will cover it under warranty. Contact the dealer you bought it from and they can handle the warranty exchange. If it is over two years old, it is out of warranty, but they offer a "repair" option, which will replace your damaged A3 with a new D3 for about $215. If you bought it from a reputable dealer, you shouldn't have any problem.
Hope this helps,
Greg DeTray
www.distagage.com
Sep 09, 2009 | Leica DISTO A5 Rangefinder
GE Profile Refrigerator clicking
Sounds like the main control board is bad . Check your warranty to see if board could still be covered .
Aug 08, 2009 | Refrigerators
Broken Nikon lens mount
I'm another very unhappy victim of the defective manufacturing and/or materials in this lens. My 18-105 DX VR lens lived in a padded camera bag when it wasn't on the camera. It's never been dropped, banged, dinged, or put under any stress. 10 months into ownership, with 50 months to go on the 5 year extended warranty, it simply came off in my hand one day while zooming. I was horrified to see a thin black plastic sliver inside the camera body -- the mount just broke off. Thankfully did not get behind the mirror or on the sensor. Greatest insult came from Nikon repair, who refused to honor the warranty because "the lens had been dropped" and asked me to pay nearly 1/3 the original cost of the lens for repairs. When I challenged this and pointed out the as-new condition of the lens, not even a scratch, they simply stopped responding to my emails and phone calls.
Jul 22, 2009 | Nikon D90 Digital Camera with 18-105mm...
Green lines at top
well i think your husband is right. it might be three years old, but the sligtest damage can kill it. so what you need to do is start saving up for a new tv. sorry for waht happened. maybe somebody hit the screen?
Sep 01, 2007 | RCA 27R410T 27" TV
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
