Question about HP Tools & Hardware - Others
Florabest submersible pump FST 1100 A1
Opening pump for service
  • HP Master
  • 3,368 Answers
That pump is sealed and not normal opened by the user. If you do not assemble it correctly it will become a shock hazard.
Posted on Jul 01, 2014
Pump continuosly runs after water is cleared out of basin
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Mar 24, 2014 | Hydromatic Pump Hydromatic V-A1...
go to the local tools shop and this blade will be in a collection of assorted blades that you need to remove a variety of screws.. Most use a special screw driver handle (in the assortment) or a small socket that fits the shaft.
Jan 03, 2014 | Tools & Hardware - Others
I can't find a supplier to replace the battery on my Florabest cordless grass trimmer, ref FRT 18 A1. The batter has a ref too, Accu Pack 18MB 1700. Thanks.
Search the internet for companies that rebuild battery packs there are many out there to choose from.
Nov 04, 2013 | Garden
I have a Florabest cordless grass trimmer, ref FRT 18 A1, which I purchased in England over a year ago. It works well, but I think the battery needs replacing. I can't find a supplier anywhere. The...
You could try searching for strictly a battery supplier who might be able to cross-reference your battery to something equivalent.
Pump for old willies dilemma fountain by Henri studio
There are a lot of non submersible pump which are available in the market however, a submersible pump would offer you less trouble of piping connections and maintenance.
Sep 11, 2013 | Henri Studios Henri Studio Wee Willie's...
Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Apr 17, 2010 | Tsurumi Pump s Submersible Trash Pump -...
My irrigation pump starts runs for a minute or so than stops after several minutes it repeats this cycle. it is a submirsible pump. I have checked the pump start relay and it appears to be functioning. Any...
Of course, the pump start relay is okey. Your submersible pump is either overpumping/ or overloaded. Check the amperage while pumping using a clamp ammeter. Set it at 50 or 100 amp. Note the reading in amperes and compare this with the rated current posted at the pump control. It should not exceed the posted rated current. Assuming it is okey, then, it is overpumping. Your submersible is
drawing more water than what the well produces.
Solution:
To correct both situations, run the submersible pump
with your gate valve at full close position, and slowly
open the gate valve, until the pump runs smoothly.
Try it with the gate valve 1/4 open. Count the number of turns to get it full close from a full open position.
Divide the number of turns by 4, and the result is the
number of turns to open for you get 1/4 open valve.
Just send your e-mail for further assistance. God bless u.
Oct 26, 2009 | Plumbing
No water on submersible pump
I assume this is a new instalation or you just removed and reinstalled to pump. As you have power on the load side and we assume your wiring to the pump is correst, you need to open a valve on the output side of the pum and bleed the pump. They will become air bound, Leave the valve open until it flow freeley. That should do it
Good Luck
Jan 23, 2009 | Submersible Systems 1/2HP 2WIRE...
Tools & Hardware - Others Logo
53 people viewed this question
Top HP Tools & Hardware - Others Experts
Gil Shultz
Lawrence Oravetz
Are you a HP Tool and Hardware - Other Expert? Answer questions, earn points and help others
