Question about Kenmore Washing Machines
I started my wash cycle. the tub filled with water then just shut off. It's acting as if the machine is not getting any power to it, but their is power at the outlet and it should be working
    Problem Solver:
  • 12 Answers
What brand? It could be a lid switch.
Posted on Jun 19, 2009
  • A Rogers Sep 30, 2011
    hey kc135q095
    did you ever find a solution to your washing machine problem??? i have the exact same thing going on right now and i CANNOT live without my washer!!! help PLEASE!!
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Water continues to fill the tub. Will not shut
Hello.......It is possible that the little tube running from the pressure switch to the tub is holed.......if so the water will continue to fill and the appliance will not start...Follow the tube down to the tub..or expansion chamber examining it for damage .you can repair this by splicing or replacing the tube..
regards Sir Galahad
Aug 27, 2009 | Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    COLD WATER DOESNT SHUT OFF AND SPIN CYCLE STARTS AND STOPS
    The pressure tube switch tubing gets clogged on these machines. The best way to repair is remove the 4 torx screws securing the control panel, On the water level switch remove clear tube from switch, with some water in tub, i suck water up and back down the tube, clearing the tube. After tube is clear spin machine for 3 mins. Test water fill again.
    Dec 04, 2007 | Washing Machines
    Washing Machines Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
