Question about Beko Genuine Washing Machine Door Gasket Seal 2814270100 Wma765w
Beki washing machine WM6143W
After washing a heavy bedspread the machine failed to spin. Drained water and rearranged spread, drum now not turning to wash and will not spin. Is this a major problem and would it be better to buy a new machine?
4 Suggested Answers
  • 3640 Answers
SOURCE: Machine won't wash but will spin
If your washer doesn't agitate, check these:Lid switchMotor couplerBeltsClutchDrive motorDrive pulleysTransmissionAgitator good-day !
Posted on Feb 07, 2012
  • 867 Answers
SOURCE: my beko 1613 washing machine wont drain, and how do i operate the dial
You can find the user manual at the below link, check it out and see if you are operating the machine correctly, It sounds like your pump may be blocked also.
Link:
Posted on Mar 11, 2012
kevin_getz
  • 1031 Answers
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
Posted on May 22, 2012
My Bosch Excel 7 1400 express won't spin heavy bathmats with the result of me having to let them drip for a couple of days to lighten the weight! very inconvenient! have tried redistributing but doesnt...
Heavy Mats, Coats, Bedspreads etc....Your balance sensor will shut it down as you have heavy mats full of water they are very heavy. If it didn't your machine would self-destruct. You might try a commercial laundry as their machines are designed (bolted to the floor) to handle various heavier loads. Even those will shut down if it senses to heavy of a load though.
Hope I helped
Jan 09, 2018 | Bosch Washing Machines
Knocking from the drum
You really should realize that when clothes get wet, they get heavy. If those heavy clothes are sticking to one place on the drum it will be out of balance and knock at the sides of the washer. If this happens, simply open the door (not when the washer is full of water, of course) and the drum will stop spinning. Just spread the wet stuff around the drum surface and close the door...voila!
Jan 12, 2013 | Electrolux Washing Machines
I got a ue code
UE means unbalance error. It means the machine can't balance the clothes in the drum so it won't spin to prevent excessive vibration and damage to the machine.
Usually opening the door and rearranging the clothes helps, or take some out then put onto a rinse and spin. If there is just a few items in then it will struggle to spread them around and balance.
Mar 02, 2011 | LG Washing Machines
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite washer, model # 22942101 Spin cycle not working. The water drained out but the drum does not spin. It smells as if something burned out.
If the water drained out, then it sounds like the motor is still good.
I would check if the brake were failed in some manner since you smelled something, and if that is OK, then it's probably a failed gearbox.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
We just installed a new GE washing machine and just tried to wash our first load (a large bedspread). When the machine got to the rinse - spin cycle, it really made such a racket and moved about on the...
There's a very good possiblity that the washer may require some leveling, but there's a lso a good possibility that the bed spread may have caused the problem. If the only thing you were washing was the bed spread this can be a difficult weight to distribute EVENLY around the wash tub when the washer goes into the spin cycle. This problem can be common when washing single large items such as bed spread, comforter, sleeping bag, etc. The tub needs to stay balanced in order for the spin cycle to run with no vibration.
To check the level of the machine, it needs to be level front-to-back and side-to-side. Also, the flooring UNDER the washer needs to be substantial enough to support the weight. If the floor flexes, your washer will walk. This can be common in mobile homes and upstairs laundry rooms.
If you need a manual for the washer, try geappliances.com. In the Search window, use the drop down menu and select "Use and Care Manuals". Type in your COMPLETE model number in the adjacent window and you should be able to find what you're looking for. If your owner's manual is not listed, the web site posts a toll free number (1-800-626-2005) that you can call as well.
I hope this helps you.
Mar 17, 2008 | GE WDSR2080D Top Load Washer
Beko Genuine Washing Machine Door Gasket Seal 2814270100 Wma765w Logo
18 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
