Question about Vehicle Parts & Accessories
I have a 2006 dodge grandcaravan i went inside store when i came out notice water under the van went todrive home it started dinging looked down seen it was hot pulled over waited til it cooled added water and it came straight out onto the ground thinkingits my water pump
  • 3 Answers
Need to put it up on a lift, put water in it and see where it is leaking. Could be water pump, hose, freeze plug. or timing chain cover gasket,
Posted on Apr 19, 2014
Testimonial: "Thank you was a hole in the pipe bought a new one for 50"
  • andea harp
    andea harp Apr 27, 2014
    also have a 2006 cummins that is over charging my batteries took out alnator any thoughts what it could be altnator is good
  • Jon Dow Apr 27, 2014
    you probably have an extenal voltage regulator. Follow the small wire attached to your alternator and it should lead to the voltage regulator.
My mother went to the store shut van off, went inside. when she came back got in the van and tried to start it wouldnt styart and we havnt been able to get it started since , HELP!!!
Motor doesn't turn over or it doesn't start ?
If it turns over, the fuel pump may have quit
Cycle the key & listen for it near the tank
Mar 27, 2013 | 1998 Dodge Caravan
2004 Caravan temp light and rapid dinging
If you have a problem with a light check your temp gauge. Chrysler warning on engine overheating responds that way and as the engine becomes hotter the chime becomes more rapid. Check your antifreeze and fluid level, this may be the problem.
Jul 06, 2012 | Dodge Caravan Cars & Trucks
Replace heater resistor 1998 dodge grandcaravan 3,8
Click HERE for instructions with detailed photos on replacing the blower motor resistor in 1996-2001 Dodge and Chrysler mini vans.
Nov 16, 2011 | 1998 Dodge Caravan
Replace heater resistor for 1998 dodge grandcaravan 3,8
Look on firewall under hood almost directly behind shock mount. 2"x 3" block with connector. Remove connector and small screws at each end and pull to side and out. Resistor element is inside firewall, just connector etc on outside.
I have a 1996 Dodger Grand Caravan with a 3 liter V6. Over the last two years we've seen the van eithr stall or hesitate when being driven in the rain (not snow or cold temperatures, just rain). It will be...
The problem is moisture could be getting in anywhere. I try to diagnose this problem by using a misting spray bottle of water to get things wet under the hood while the car is running. It's safe as long as you don't spray water down the air intake. Just start the van and wet down anything that looks electronic until the van's idle stumbles or quits. A cracked coil pack or bad plug wire is the most common cause of this problem.
Mar 14, 2011 | 1996 Dodge Grand Caravan
The cooling fan relay went out in my 2000 dodge grandcaravan 3.3L. Can you please tell me where it is located so I can replace it?
FUSE AND RELAYS LOCATED UNDER THE HOOD IN THE ENGINE COMPARTMENT.TO LOCATE RELAY LOOK IN GLOVE BOX FOR OWNERS MANUAL IT WILL TELL YOU TELL WHERE THE COOLING FAN RELAY IS SINCE THERE ARE MANY OF THEM.
Jul 05, 2010 | 2000 Dodge Grand Caravan
Came home today and after a few hours noticed a large puddle of tranny fluid under the van. Followed it down the driveway and a little ways down the road. Two very noticable lines on the road leading into...
It's likely rusted out transmission cooler lines. Only way to tell is to take a look under it. Might be able to see some of the line by opening the hood.
Oct 12, 2009 | 1999 Dodge Grand Caravan
Liftgate on van not working at all
There are 2 support shocks that support the lift gate. You need to replace them. One or both of them are no longer supporting the door. Your local auto parts store will have them in stock. Compare prices with competitive stores, prices vary depending on where you purchase them from. It't really easy to replace them.
Apr 06, 2009 | 2005 Mercury Monterey
Cant find filter
in front of the windshield under the air intake grille, turn on the high blower, choose outside air, listen where the air is being pulled in, that is where the filter is.
Feb 26, 2009 | 2006 Dodge Grand Caravan
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
