Question about Magicard Rio 2e - Ethernet - Single-Side Printer
Cam motor or sensor fault.
Mis cam position
    Scholar:
  • 71 Answers
Hello Abdul,
Sorry to hear that you are getting a CAM mis-position error 09:00 / 09:01.
Please check the following;
Open and close the lid. Listen very carefully. Can you hear a motor running for a few seconds and then stopping?
It may be a simple belt / pulley issue.
This PDF document should help you find the cause.
http://www.magicardonline.net/temp/cam_mis-position_error.pdf
Let me know if you need anything further.
Kind Regards,
MC.
Posted on May 02, 2014
2007 Saturn Aura XR 3.6 code p00116. new timing chains and all parts...128,000 miles any ideas besides the crankshaft reluctor.. Car runs great idols smooth
you got a bit carried away with the code
code p 0016 refers to crank shaft position/cam shaft position sensor, bank 1 sensor A---correlation === causes --wiring---CKP sensor --CMP sensor ---mechanical fault
code p 0011 refers to cam shaft (CMP) intake /left /front bank 1 --timing over advanced / system performance==== causes ---valve timing---engine mechanical fault --- CMP actuator ---wiring
you didn't mention the fault so consider this
if the timing is out on the intake cam shaft , it will idle good but play up as the timing actuator moves it further advanced with rpm
if the actuator is not wire properly or the solenoid is faulty , then the inlet will lag with increased rpm and again cause you problems
It is doubtful if the position sensors for either the crank or cam shafts are a problem because it starts and idles good
Nov 12, 2017 | Saturn Cars & Trucks
I have trailblazer 2008 4.2. p0014 and p1174
0014 = "B" Camshaft Position - Timing Over-Advanced or System Performance Bank 1
1174 =
Citroen/Peugeot:
Cam Sensor Fault
Daewoo:
ETS VALVE STUCK - CLOSED 1
Ford:
Cam Sensor Fault
Hyundai:
Electronic Throttle System #1 Close Malfunction
Jaguar:
System Too Lean - Banks 1 and 2 (Suspect HO2S)
Kia:
Lincoln:
Cam Sensor Fault
Mercury:
Cam Sensor Fault
Oldsmobile:
Cam Sensor Fault
Volkswagen/Audi:
Fuel Trim,Bank 1 Different injection times
Volvo:
Aug 19, 2017 | Cars & Trucks
2002 Chevy trailblazer 4.2 I6 P1345 code keeps returning
The following conditions may cause this DTC to set:
If this DTC sets, there is a problem with the camshaft position actuator solenoid high control circuit shorted to voltage or the solenoid stuck open.
An improperly torqued harmonic balancer
A misbuilt or mis-timed engine
A loose or missing crank damper bolt
The camphaser solenoid stuck open
The camphaser stuck in a position other than 0 degrees
The camphaser does not return to 0 degrees within 16 seconds
Oct 15, 2015 | Cars & Trucks
My 2001 Dodge Statues Coupe RT.has random mis fires. I have replaced bank 1 o2 sensors but it still mis fires as I give it gas to accelerate. Your thoughts? Steve
O2 sensors won't make misfires they only monitor air in the emissions if you have a random misfire it's most likely gonna be your coil pack or a cam pos sensor the cam sensor detects the location of the cam and tell the pcm and it tells the coil to fire your are getting O2 codes cause it detects unburned fuel it the exhaust
Jun 02, 2015 | 2001 Dodge Stratus
Truck will not idle right code says crankshaftposition camshaft position corrlation bank1 sensor a
Causes Causes may include: Timing chain stretched, or timing belt skipped a tooth due to wear Misalignment of timing belt/chain Tone ring on crankshaft slipped/broken Tone ring on camshaft slipped/broken Bad crank sensor Bad cam sensor Damaged wiring to crank/cam sensor Timing belt/chain tensioner damaged An improperly torqued crankshaft balancer A mis-built or mis-timed engine A loose or missing crankshaft balancer bolt The CMP actuator solenoid stuck open The CMP actuator stuck in a position other than 0 degrees.
Jan 29, 2015 | Cars & Trucks
PONTAIC G6 2008 2.4 CAM POSITION SENSER PROBLEM HOW TO CORRECT
Buy the sensor from the car dealership. The sensors at auto stores are inferior and sometimes do not work properly.
Jul 07, 2014 | 2008 Pontiac G6 Sedan
2001 galant, had cam shaft sensor replaced. Check engine light won't go off. Mechanic ran diagnostics again and said computer is reading a mis-fire in piston 1. Mechanic says there is NO mis-fire...
Ask your mechanic to please verify that he has the cam set in exactly the right position, and that the wires connecting it are still in good shape. The "misfire" could be that the computer is seeing the fuel-air explosion, and thinks it is at the wrong time due to the sensor being off.
Jul 21, 2011 | 2001 Mitsubishi Galant
2003 300M-car stops while travelling-getting a #344 trouble code- what may the problem be?
this is a CAM position sensor fault. More specifically it is an Intermittent cam shaft position sensor code. The likely cause of this is that you will just need to replace the sensor, typically they run from $40-$80 USD and can take up to about an hour to change out. they are located on the front of the motor on the top of the cylinder head. Also they do not require any kind of special tool to change out.
Jun 04, 2011 | Chrysler 300M Cars & Trucks
2001 dodge 3500 van cam position sensor location
Crank sensor is in the bell housing of the transmission. Cam sensor is in the distributor.
Jul 25, 2010 | 2001 Dodge Ram 3500 Truck
Intermittent mis-fire, stuttering at cruise speed and
My 1998 Eldorado was doing the same untill i replaced the spark plugs, i would try that.
Apr 28, 2009 | 1992 Cadillac Eldorado
Magicard Rio 2e - Ethernet - Single-Side Printer Logo
125 people viewed this question
Top Magicard Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
