Question about Fuji FinePix S5 Pro Digital Camera
How do I find shutter count on fuji s5 pro - Fuji FinePix S5 Pro Digital Camera
4 Suggested Answers
  • 241 Answers
SOURCE: how do I set my fuji s5 pro to adobeRGB
You do that in the Shooting Menu.
Press Menu/OK, select Shooting Menu, select Color Space, change color space from sRGB to Adobe RGB, press OK
Posted on Oct 23, 2009
Testimonial: "Many thanks for your help.Problem solved. Kind regards, Vic Evans"
SOURCE: S5 pro autofocus will not work consistently.
Hi - just wondering if you found a solution to your problem - as my S5 pro has the same issue.
thanks
Posted on Apr 09, 2011
tbreeze47
  • 3083 Answers
SOURCE: Hi. I have a vertical
This sounds like a problem wth the ccd (picture detection apparatus), but I saw on some web blogs that this banding can occur in low light situations, especially with a function called alo, which should be turned off to minimize this effect. I didn't see a report of this on the Fuji cameras, but it was discussed on a Canon web blog. One fellow sent his camera into the service center, and they replaced the ccd, and he still had the same problem. There was no reported "fix" for it, and one fellow said he believes it's a common problem. Another person said it occurs with his ISO set at 100, and it seems to be a inherent problem with the camera, with no apparant solution. Replacing the ccd will be expensive, and from what I've read, you might not be any better off. Some cities have digital photo clubs, and they might be able to verify this anomaly, and let you know if there's a known fix or not.
You can take the camera into a local shop to have it assessed, or contact Fuji for information about this problem, but make sure they're certain they know a fix, or you might end up spending a lot of money and not be any better off.
Good luck, and hope this helps.
Posted on Apr 24, 2011
How do i change the shutter speed on fuji s2 pro
In the P, S, and M modes, turn the command dial on the back of the camera. In the P and S modes the aperture will also change to compensate. In the A mode, turn the secondary command dial on the front to change the aperture, and the shutter speed will change to compensate.
Oct 29, 2012 | Fuji FinePix S2 Pro Digital Camera
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
How do i unlock iso-auto on the s5 pro?
Hi dear chrisofoto, You can change the ISO sensitivity setting by pressing the ISO button and rotating the command dial, also the white balance by pressing the WB button and rotating the command dial to get the desired value.
Best regards
Mar 24, 2011 | Fuji FinePix S5 Pro Digital Camera
Can't see the shutter image on my LCD????
check the menus make sure he monitor or review setting is turned on. If the camera will show menu setting but no the play back then that should be it. If the LCD is down comletely then the camera must be sent off for repair.
Jun 25, 2010 | Fuji FinePix S5 Pro Digital Camera
thanks
Apr 15, 2010 | Fuji FinePix S5 Pro Digital Camera
How do I set my fuji s5 pro to adobeRGB
Oct 22, 2009 | Fuji FinePix S5 Pro Digital Camera
I use a fuji s5 pro the problem is the sb 800 nikon flash for some unknown reason the flash fires once and then wont fire when shutter is pressed again
I think the flash is not grounded to the hot shoe or Hot foot .
Please note it needs to be cleaned and make good contact.
If you want me to tkae crae of your problem contact .
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
770-312-0719
Dec 27, 2008 | Nikon Speedlight SB-800 TTL Flash
Fuji FinePix S5 Pro Digital Camera Logo
35 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
