Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Bunn ultra-2 slushi machine not icying up - Bunn Margarita Machine Ultra 2 Slush Granita Maker
  • Bunn Master
  • 2,237 Answers
Make sure it's on ice, not chill or off. clean the rear filter and make sure there is at least 6 inches of space behind the machine for it to breathe.
Posted on Sep 08, 2014
Setting constitancy of product
I think your Bunn machine is producing the 'ice frozen drinks" it was designed for.
May 18, 2016 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
Bunn ultra-2 not icying up
make sure it's on ice, not chill or off. clean the rear filter and make sure there is at least 6 inches of space behind the machine for it to breathe.
Apr 19, 2014 | Bunn Margarita Machine Ultra 2 Slush...
Oil coming out of back of machine
it isn't oil, it's old, syrupy slushie mix and dust. the only oil in the machine is inside the hermetically sealed (cannot open) compressor. you have a front seal problem. the shaft seal in the front inside the evaporator (steel tube), and the cup-shaped seal between the auger and the evaporator. slush is getting inside the shaft tube and dripping through the inside rear of the machine. replace the seals, lube with a food-safe lube and refill.
Mar 04, 2014 | Bunn Margarita Machine Ultra 2 Slush...
I have bunn slush ultra 2. 1 side freezes 1/2 way, like slushy a little bit but still watery, other side is only chill. both are set to 16 thickness.
make sure both say "ICE" on the display. press the snowflake buttons on the front to get it there. also, make sure you are mixing the product properly. if still an issue, you may have a small refrigeration leak that should be looked at by a professional
Aug 26, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Bunn won't freeze the drink, the drum freezes and ices over but 3 hours later no slushy.
clean the filter and condenser coils, leave at least 6 inches of space for it to breathe
Aug 02, 2013 | Bunn Margarita Machine Ultra 2 Slush...
One side of my bunn ultra 2 slushie machine is leaking how do you change a bad seal to stop this problem?
remove the bowls by pushing in black button on the bottom front left of the bowl, pull the bowl up a little, then pull it forward and off. pull the auger off and the seal is opaque, cup shaped, and on the shaft. replace that, lube the edge with food safe lubricant (i.e. superlube), lube the large round bowl seal in the back and put it all back together. you may need a preventive maintenance kit installed as well, but that's a bit more involved
Sep 28, 2011 | Bunn Margarita Machine Ultra 2 Slush...
Why does my ultra bunn 2 slushy machine throw off extreme heat
Check the filter in the back of the machine that and the coils are covered with dust.
Feb 19, 2011 | Bunn Margarita Machine Ultra 2 Slush...
I didnt get instructions with my slushie maker
Check under the commercial products link on bunn.com to download a copy of the manual.
Dec 30, 2009 | Bunn Margarita Machine Ultra 2 Slush...
I need the instructions for the slushie maker.
Check out your manual. Usually, a manual will have recipes for you to use. If you don't have the manual, you might want to look into contacting Bunn to get one (usually they can send them out for free!). Their phone number (according to their website, www.bunnomatic.com ) is 800-352-2866
Good luck! :)
Aug 26, 2009 | Bunn Margarita Machine Ultra 2 Slush...
Bunn Ultra slushy machine has black goo leaking out of machine. Can't find a service professional to look at it.
black goo .. actualy syrop is leaking rom the bin and collecting in the machine.you nead to stip the machine and steam clean it . replase the seals for the auger and bin. and lubricate them with food grade lube during reasembly.. your not alone. hopefully there is no damage at the auger housings.
hope this helped
Oct 06, 2008 | Heating & Cooling
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
197 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
