Vertical amplifier the power is an open and close?
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 19, 2014
Vertical amplifier
The set indicated does not have a vertical amplifier.
Apr 23, 2012 | Televison & Video
P61940 Sound but no picture
Could you gives us more info on how or from where you get the video source to your TV?
Jul 04, 2008 | RCA P46921 46" Rear Projection Television
My TV is death
hi
open your tv clear dust , check capesitor,power supply ,transi sotr ,regester,
Mar 24, 2008 | Samsung SlimFit TX-S3082WH 30" TV
I've found the fuel shutoff valve. How can I tell if it is opened or closed? Is it vertical or horizontal if it is closed?
Usually, the fuel shutoff valve is open in the vertical position and closed when horizontal...very similar to a gate valve...open when handle is parallel to piping and closed when perpendicular to plumbing pipes.
Jan 08, 2011 | Briggs & Stratton Electrical Supplies
My screen wont play or fold in on my nitro dvd player
Sounds like there is a powering problem with it. You could check the power cable. If thats not it, sounds like a defective radio.
Mar 10, 2010 | Nitro BMW-486 Car Audio Amplifier
When I press my open/close button the sliding panel doesn't work
good day, you may try to open manually, theres a little pinhole that you can see try inserting a paperclip in the hole and tray will open manually, hope this helps, have a nice day
Feb 10, 2010 | Kenwood KAC-X201T Car Audio Amplifier
Nad c350 no power at all
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
NAD C370 problem
I would suggest that the fuse in the amplifier has blown. This is usually caused by a bad amplifier component (duh!).
The unusual part of your problem is that sound is being passed. When a component dies, signal stops as the continuity is broken.
Which could also suggest the power supply. Transistors work like relays, you turn on the control signal and the transistor opens or closes. It isa possible that this control voltage is not being passed.
Either way, this will require shop work
Jeff
Jun 14, 2008 | NAD C370 2-Channel Amplifier
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
