Question about Whirlpool Mastermind
Water comes in the fridge
Drops of water comes inside the refrigerator after every 4 hours
4 Suggested Answers
  • 142 Answers
SOURCE: Sound of Water coming from internal backside of freeze
Your unit was in defrost mode (happens once a day) and ice that built up over the previous 24 hours was melting and draining down a drain line to a pan under the unit so it will evaporate. This is how freezers stay " Frost free ". The water in the pan under the unit will evaporate by itself. Have a great day!
barneyluc
Posted on Oct 10, 2008
  • 9 Answers
SOURCE: Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
Posted on May 12, 2009
heatman101
  • 43501 Answers
SOURCE: sir, my fridge is leaking
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 27, 2010
Water drops come inside the whirlpool mastermind refrigerator every 4 hours
Do they drain away down the back? It is probably just an automatic defrost cycle. check the stock temperature is ok
Apr 19, 2014 | Whirlpool Mastermind
Hotpoint ctx18ea fridge not cooling
Kimberley, try this:
First see any sign of ice build up in the freezer.
1. Switch off power from wall outlet.
2. Open the fridge door and freezer door and keep them open for atleast 5-6 hours. Salvage whatever food you can.
3. You may now see a puddle of water under the fridge. Clean the floor and inside of the fridge if water and other fluids visible .
4. Now re-connect power and set the recommended settings- usually at 4. Close doors.
5. Your fridge will be making a humming sound. Let it begin to cool.
Good luck
Apr 05, 2014 | GE Refrigerators
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Ice maker works but water won't dispense
There is a know defect with the freezer side door. read more at http://www.houstongofarappliancerepair.com/Refrigerator.html
Also, If you call and haggle GE they may send you a new freeezer side door. Or, You may actually try turning fridge off, leaving door open for about 4 hours and then try it again. As strange as this sounds it has worked for some of my customers.... When "air-bubbles" get into that line it can freezer inside the door a small section of water line because the insulation in freezer side door isn;t thick enough... More can be read on this problem at http://www.houstongofarappliancerepair.com/Refrigerator.html
goodluck...
Dec 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water inside chefmate refrigerator
Moisture inside the 'fridge condenses on the coolest parts. Most are designed so that the moisture runs down into a channel and is directed out through a small tube somewhere at the back of the compartment, near the bottom.
I would guess that the tube is blocked near the top.
Try finding the tube and carefully inserting something flexible down it to clear the blockage. Don't use anything too rigid, or anything metallic, as these may damage the tube and cause more serious problems. I have done this before using a pipe cleaner.
Jun 06, 2008 | Refrigerators
Water dispenser : the water freeze
All,
I hve the same problem of the water not coming out. After reading this forum that suggested this is caused by a frozen line, I increased the temperature (less cold) of the fridge and freezer, and turned on the light (generates heat in the area). After a couple of days, the water worked.
Tom Z
Feb 04, 2008 | GE GSH25JFR Side by Side Refrigerator
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Mastermind Logo
22 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
