Question about Kitchen Appliances - Others
How do you open a zing ear 127f switch?
It has 2 slots on the bottom marked "open". Stuck a screwdriver in the slot and tried pushing and twisting the blade, but it would not open.
Any luck? I have the same question.
Posted on Jun 17, 2014
  • Johnny M
    Johnny M Jun 17, 2014
    I just figured it out. Stick a flat head screw driver in the hole opening for the wire and twist agains the inner plastic ledge. The housing will pop off.
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
5 wire, 4 speed Ceiling Fan Switch - Hunter
You should be able to assuming you have the correct switch. Don't use the 4 slot in switch.
Dec 29, 2012 | Dryers
Where can I find a replacement switch. Zing Ear ZE-268S6. Thank you.
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
Jun 27, 2011 | Hunter Ceiling Fan Light Switch Control
I have a hunter fan and my contractor switched the load and green wire in the new zing ear switch. I just need to switch the 2 wires and I can't get the switch open. can anyone help?
I found out that mostly they are connected with fastons. You can get them at hardware or auto parts stores.
From what I've heard Zing Ear switches are a bear when it comes to taking apart or taking off wires.
Good luck.
I hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Vacuums
I have a kenmore 106.53664300. How do you remove
Kneel down and look up from the bottom, you will see 2 small slots on the bottom, insert a putty knife or screwdriver in the slot and push up hard or twist slightly. If you gently pull on the bottom front while doing this it will help release. Once this is loose you can disconnect the wires. Be sure the frig is unplugged!
Apr 18, 2010 | Kenmore 53642 / 53644 Side by Side...
Zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
I want to re-open a Zing EAr ZE-127F switch
I got the same switch and can't figure it out either. Did you come up with a solution?
Sep 12, 2009 | Kitchen Appliances - Others
Ceiling Fan Light Chain Broken; Zing Ear
It's actually a very easy repair. Those pull chain switches are very generic and can be found at home depot or any hardware store for about $3. As far as changing the switch there are only 2 wires to connect and there is no incorrect combination to reconnect them.
Sep 03, 2009 | Hampton Bay 24750 Huntington III Ceiling...
1999 Buick Century /need to know how to remove the plate attached to rear view mirror so it can be re-stuck to windshield
With a pair of vice grips get it griped enough not to dent the metal and twist left to right to break the seal, put cloth on them to keep from breaking glass, then clean with alcohol.
Jun 26, 2009 | 1996 Buick Park Avenue
Kitchen Appliances - Others Logo
391 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
