Question about Sharp XE-A106 Cash Register
Paper will not feed
Whn I put the paper in and hit the feed it will not come out
  • Sharp Expert
  • 591 Answers
It could be that the cover is not in the rightful position . Push the cover hard down or you feed gear is worn then you need to replace it
Posted on Apr 23, 2014
How do I change the paper tape roll on casio HR-100TM?
Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
Mar 02, 2011 | Casio HR-100TMPlus Calculator
How do I put paper into it
Cut the paper off clean.
Slid it through the slot on the back.
The place the paper between the black plastic rail,
and the bottom of the calculator.
Keep feeding it in the slot untill you can see it under the
foam wheel.
The repedably hit the feed button until the paper comes
out the other side.
If it does not feed, the paper is not under the wheel far enough.
This should work on other similar models as well.
Jan 11, 2011 | Casio HR8TM Calculator
Epson c-88 won't feed paper
Hello sir; You may go to computer to set up; Hit print then go to preference then paper/quality then you can choice the type of the paper you want to print, good luck.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson 7600pro air in ink line
You can try an Initial Fill of your ink carts. It is the next level after attempting to clean the heads. However, if this only temporarily fixes your problem, you could have a leak in the supply tubes, or the head could have failed.
Turn the epson off. Hold down the buttons [Paper Feed δ]+[Paper Feed ∇]+[Cut/Eject] and turn on the printer. This will take you into a hidden service menu. Hit the [Paper Feed ∇] button until you get to "Cleaning" then hit the [Select] button to enter that submenu. Hit the [Paper Feed ∇] again until you see "Init Fill", and then hit the [enter] button. The display will say "charging". Just wait until it is done, then turn the printer off and back on.
If you do not have enough ink in the in the carts you will be prompted to replace them. The same goes for the maintenance tank. Make sure you put the ink lever back in the lock position if you change the carts. (It will not give you an error about the ink lever being down, it just won't do anything.)
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
My HP OJ 7310 all-in-one did not pick up papers.
the first ting I would do is clean the paper feed rollers with a cotton pad and alcohol. The rollers may have a build up of paper dust that are makind the rollers slip.
Sep 27, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Adding paper
There is no manual available for this model online.
However, there are two basic methods. Always make sure you are puting in paper that has been cut cleanly with scissors, not torn, as this can ruin your printer. If you have a slot on the back of the machine, just under where the paper roller typically sits on the holder, with the calculator off feed the paper in that slot (rolling out from the bottom). Then turn the printer on, and hit the feed to advance the paper into the printer.
If there is no slot on the back, you will see that the opening where the paper comes out from the top is "subdivided", and when it has printed, it is coming out of the front partition of that slot. Make sure the printer is off, feed the paper into the back portion of the opening, rolling from the top. Then turn the printer on, and hit the feed to advance the paper into the printer.
Either method should solve the issue exactly, and once the paper has fed in, then place the roll onto the holder. You're set!
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jun 07, 2008 | Canon P23-DHV Calculator
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer1.gif assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Mar 21, 2008 | Ibico 1202 Calculator
E studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Oct 11, 2007 | Toshiba e-STUDIO 16 Printer
Sharp XE-A106 Cash Register Logo
81 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
