Question about Sharp XE-A106 Cash Register
The tap will now feed
I put the tap in and hit the feed and it will not work
  • Sharp Expert
  • 592 Answers
Properly close the head cover
Posted on Apr 23, 2014
How do I put paper into it
Cut the paper off clean.
Slid it through the slot on the back.
The place the paper between the black plastic rail,
and the bottom of the calculator.
Keep feeding it in the slot untill you can see it under the
foam wheel.
The repedably hit the feed button until the paper comes
out the other side.
If it does not feed, the paper is not under the wheel far enough.
This should work on other similar models as well.
Jan 11, 2011 | Casio HR8TM Calculator
Feed the string
Both lines run in same direction on spool. Make sure it is not pinched or fed through any of the arms in the spool just coming out one on each side of the hole. Tap bottom on ground while trimmer is running to feed line. Each time you tap it line comes out approx 2 inch at a time Common mistake is when new line is added it gets put on in opposite directions. Both do they same direction-arrows on spool tell the way.
Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
I cannot get my copier to copy papers. Please refresh my memory on how the 5610 all in one copies. Thanx
We have a 6210 at work, must be similar though.
Make sure you have blank paper in tray, Put piece you want copy of face down on scan glass, close lid, hit copy, it takes a minute to wake up. Or put piece you want copied in auto-feed face up, hit copy, it takes a while to wake up, seems as though it is not working, then it will.
Jun 15, 2010 | HP Officejet 5610 All-In-One InkJet...
We used to have a separate toilet next to the bathroom. When we have the loft extension built the WC was relocated to the bathroom to make way for the new staircase. Since then we have very low pressure...
The water all comes from the same place usually. What you need to check is your supply line to that area the supply should be larger than the feed lines, depending on the code in your area. The supply carries more volume to your usage areas that's why it should be larger, then you tap off of the supply with smaller pipe to connect feed lines to receptacles. To long of small feed line runs lead into problems maybe such as you have. Was the job inspected by your town or local agency? They might have caught such a discrepancy.
Jun 08, 2010 | Plumbing
Low pressure from immersion heater to mixer taps on bath can i fit a pump on the pipe work leading to the bath
You need to have an higher head of water on the tank that feeds the cylinder that the immersion heater is fitted to. Put the tank on a framework say 3 foot above its present level.
Regards
Alan Hood
ami-man
UK
May 10, 2010 | Plumbing
4Hi won't switch back to 2Hi
First try hitting the 2HI when in nuetral. If that doesn't work put the vehicle in reverse and hit the 2HI switch and tap the brakes at the same time. Usual if you do this, when you put it into drive it will release.
Mar 24, 2010 | 1999 GMC Jimmy
Will not feed paper to print
Do a Mr. clean act on all rollers coming in contact with paper. I use distilled alcohol and cotton and it has worked for me.
Sep 06, 2017 | Dell 1700n Laser Printer
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Breaking needle
Sounds like the timing is off, have to take foot off, take plate off, put it in the zz position and using the hand wheel turn(with new needle in) and see where it is hitting feed dog, loosening the screws to the feed dog and moving it in the opposite direction out of the way so as not to hit. let me know how that works
Aug 08, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sharp XE-A106 Cash Register Logo
51 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
