Acer motherboard fq965
Front panel LED pins
  • 349 Answers
SOURCE: Pin settings for Acer Veriton 5600g motherboard
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
Posted on Feb 20, 2008
myob247
  • 1342 Answers
SOURCE: emachine front panel power switch
Here's the Support Link for your desktop. Look under User Guides, Hardware Reference. Also look on the motherboard for markings such as PW or PS and an indicator to where the wire goes.
Posted on Nov 23, 2008
  • 357 Answers
SOURCE: ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Posted on Feb 06, 2009
SOURCE: connecting front panel leads of generic case to 4600 motherboard
-MrSlickShoes
Posted on Mar 20, 2009
mukexh
  • 20 Answers
SOURCE: need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
Posted on May 13, 2009
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
Sep 23, 2014 | Acer Aspire 7720 Notebook
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
I need help with hooking up the front panel wires from a acer veriton 460 on to a asus p5g41t-m lx plus mother board
I don't think it's gonna' fit.
Acer Veriton L460 computer Case Dimension specifications,
http://support.acer.com/acerpanam/desktop/0000/Acer/VeritonL460/VeritonL460sp2.shtml
Chassis: 2.5 inches Wide (63.55mm) x 10 inches Long (254mm) x 8 inches High (203.2mm).
Asus P5G41T-M LX motherboard is 9.6 inches LONG, (244mm), and 7.9 inches High (201mm).
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#specifications
However,...........
If you do not know what the Power On switch, Power On LED light, and Harddrive activity LED light wires are, then remove the Front Panel, and trace them back.
(Side Panel then Front)
Click on the Download tab.
(Overview / Specifications / Download / etc)
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#download
Click on any O/S. They will all get you to the Manual download.
Click on the + sign to the left of Manual (12)
Scroll the inside blue bar down until you come to -
Version E7096 -
P5G41T-M LX User's Manual (English)
Click on the blue - Global
A small window will come up on the right -
Opening E7096_P5G41T-M_LX.zip
[This is a Zip file. A Zip file is used to send large amounts of information, more easily. A Zip file is a Compressed file. It needs to be uncompressed after downloading, or can be stated as 'unzipped'.
If WinZip is no good on your computer, then just download the free 7-Zip ]
Make sure there is a Green dot in the small circle, to the left of Save File.
If there is no Green dot; left-click in the small empty circle to the left, of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this window.
Then DOUBLE-click right on the file name.
On the left side in the next window, click on - Extract all files.
At the bottom of the next three small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click on the file name -
E7096_P5G41T-M LX, next to the red Adobe PDF icon.
Page 1-6 (16 of 62) shows the Motherboard Layout.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel connect to, is the Front Panel header.
Motherboard installed in computer case; Processor to Top, Ram Memory slots to the Right, white PCI slots to the Bottom;
the Front Panel header is below the bottom white PCI slot, and next to the bottom edge of the motherboard.
F_PANEL
4 pins across the Top row, (Then no pin)
5 pins across the Bottom row.
1.10.2 Internal Connector section - Page 1-26 (36 of 62)
8. System panel connector (10-1 pin PANEL)
Pins aren't numbered, I'm going to number them;
Pins across the Top row are numbered EVEN.
Pins across the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right; Top row,
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the Left side going towards the Right; Bottom row,
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. 5 Volt power reserved for the factory.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10. Just a flat spot.
The small 4-pin header immediately to the LEFT, is for an internal speaker. Used to hear BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
The Front Panel USB header is listed, and Firewire ports. (1394a)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Acer Power S290 PC Desktop
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Nov 01, 2012 | Acer Power S290 PC Desktop
Motherboard diagram Acer eMachine MB DA061/078L
Hello? Tap, tap on the monitor. What are you reading from?
http://www.ebay.com/itm/Acer-MB-NB107-001-DA061-078L-Motherboard-eMachines-08120-2-780G-AM2-Desktop-/280919767281?pt=Motherboards&hash=item41681f78f1
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
Motherboard installed in computer, the Front panel header is at the Bottom/Right.
Two rows of 7 pins in a small black rectangular plastic block.
http://www.ebay.com/itm/Acer-DA061-078L-Motherboard-eMachines-EL1200-X1200-AMD-780G-Socket-AM2-DDR2-/140825131784?pt=Motherboards&hash=item20c9d4fb08
TOP row of pins is numbered EVEN.
BOTTOM row of pins is numbered ODD.
Starting on the LEFT side going towards the Right, TOP row:
Pins 2, 4, 6, 8, (NO 10), 12, and 14. Again, there is NO Pin 10.
Starting on the LEFT side going towards the Right, BOTTOM row;
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pins 2 and 4 are for the Power On LED (Light)
4) Pins 6 and 8 are for the Power On switch.
5) The rest of the pins are N/C. Not Connected.
Don't forget to plug the 4-pin ATX +12 Volt power cable in,
(Top left corner),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Regards,
joecoolvette
Sep 06, 2012 | Computers & Internet
Power front panel conectors on acer 915m08
This Foxconn 915M08-G-8KS motherboard made for Acer Veriton desktop computers?
http://www.sella.co.nz/general/computers/components/motherboards/other-motherboards/b1jnj6/
Do not know what the Front Panel header pinout is.
(Front plastic part of computer tower is the Front Panel.
Area of contact pins on the motherboard, that the wires (Cables) from the Front Panel connect to, is the Front Panel header )
CAN see by clicking on - View full size image - that the Front Panel header is to the Top Left corner of the motherboard, by the CMOS battery.
(View of mobo is upside down, in relation to how it actually sits in the computer tower case)
Shows me it is just the normal two rows of contact pins used in a LOT of desktop computer mobo's. (MOtherBOard)
If it were I, I would use one of the LED lights connected to two wires, and touch across each two sets of pins.
Looking at the motherboard as it sits in the computer case, there is a row of pins on Top, and a row of pins on Bottom.
In your mind start at the LEFT side of the pins at the TOP.
Number them from Left to Right.
Example, Pins 1, 3, 5, 7, and 9.
Now number the pins on the Bottom, from Left to Right,
Pins 2, 4, 6, 8, and 10.
Computer plugged into power, touch the two wires of the LED light, to Pins 1 and 2.
Computer doesn't start? (Power Supply turns on)
Go to the next set of pins.
I am willing to bet Pins 5 and 6 turn the Power Supply on.
No? Keep experimenting.
What will happen if you touch the WRONG pins?
N-O-T-H-I-N-G
You will NOT hurt the motherboard.
When you get to the correct pins, the Power Supply will turn on.
These pins are for the Power On switch.
Now go back through the pins with the Power Supply on, but DO NOT touch the pins that turned the Power Supply on.
When the LED light STAYS on, you have the pins for the Power On LED light.
If the LED light BLINKS, you have the HarDDrive activity LED light.
If Windows starts to load, and you touch the Restart switch pins, the computer will restart over again, and Windows will load again.
(IF this computer has a Restart switch. I do NOT use one, even for the older computers. Just press CTRL, ALT, and DELete keys at the SAME TIME, to restart the computer, or use the Task Manager option)
One pin left all by itself? That is for 5 Volts, and only used by the factory. Leave it unconnected.
There may also be a blank spot on the Front Panel header, where it looks like a pin is missing. This is the KEY pin, and is not used.
It is just to orient where the other pins are.
Worried about getting shocked?
There may be a small spark, as you connect the wires, I will gramnt you that.
But the voltage is 5 VOLTS DC.
In comparison two D cell flashlight batteries produce 3 VOLTS DC.
The harmful AC voltage is contained in the metal enclosure, of the Power Supply. Can't get you unless you pour water on it close up, or stick a metal rod through one of the ventilation holes, in the Power Supply enclosure.
Regards,
joecoolvette
By the by. You could be a lot of people's hero, if you came back, and posted the pins for what they do. Post in a Comment.
Jun 08, 2012 | Acer MB.V1509.002 VERITON 7700G VT7700G...
Mercury Motherboard PI845GLM-L manual needed for wire connections... please help me
If my information is correct;
Orient the motherboard so that we are both looking at it in the same direction,
Processor to the top, Ram Memory slots to the right, white PCI slots to the bottom.
The front plastic panel of your computer that has the Power On button, Harddrive activity LED light, and Power On LED light, is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is all the way down on the right corner. Panel 1.
The Front Panel header, or Panel 1, is a rectangular block that is positioned lengthwise, across the bottom of the motherboard.
There are 4 pins across the Top, and 5 pins across the Bottom.
The pins are numbered.
They are numbered Even across the Top row.
Pins 2, 4, 6, and 8. (There is NO Pin 10. Just a blank spot)
They are numbered Odd across the Bottom row.
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
Pin 1 is for the Positive wire. ( + )
{ Pin 2 is for the Negative wire. ( - ) }
If the LED light is dim when operating, turn the wires around.
B) Pins 5 and 7 are for a Reset switch, (Reset button), IF a Reset switch is used.
Pin 5 is for the Negative wire
C) Pin 9 is RVSD_DNU
Reserved Do Not Use.
D) Pins 2 and 4 are for the Power On LED light.
If the LED light is dim turn the wires around.
Regards,
joecoolvette
Sep 16, 2011 | Mercury P4VM800M7 Motherboard
Theirs no indication where about to put the power switch,power led,reset switch and HDD led in motherboard acer veriton 3600g?
The connections are printed on the edge of the MoBo under the pins. With the back panel on your left the front panel connector pins are on the bottom right bottom row should be (from left to right) PWRLED PWRSW
The row above HDDLED RSSW
Apr 09, 2010 | Acer Veriton 3600 (V3600GT00150) PC...
Acer m464 front panel connectors
Sorry in the 1st instance for my lack of specific knowledge when it comes to ACER hardware.
Is the model of your MOTHERBOARD - Acer m464?
If so do you happen to still have a manual that came with the motherboard?
Sometimes you can see the pinout in white writing on the mainboard itself near the connector block... have a close look and see if it is there.
The pin out for the connector block will definately be in the mainboard manual. If you don't have the manual then you'll need to do a little searching for it... I'm sure a .pdf of it will be floating around... i guess start at the ACER site.
On the rack mount chassis, are the plastic chassis connectors grouped (ie. 2 wires into 1 connecter for pwr led, etc) or are they individual single pin connectors?
Either way for each group, one should have a little TRIANGLE on the opposing side to the writing. Conventionally this is your positive (+) pin when looking at the pinout diagram. Ensure you have correct polarity for all ur connections obviously.
See how you go mate.
Mar 25, 2009 | Acer Computers & Internet
Acer motherboard MS6772 ver 1 Can you help me with the pin out for connector FP1 please This is the connector with reset and power switch drive led etc
This board uses typical INTEL styled pin header for front panel connections and is used on many major OEM boards. Here is the pin assignment:
Pin 1-3 HD LED (Red color in this particular board)
Pin 2-4 Power LED (Green)
Pin 5-7 RESET
Pin 6-8 Power ON/OFF
Note: Pin 10 is empty
Mar 10, 2008 | Acer (ACERMOTHERBOARD)
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
