Question about Panasonic ET-LAM1 Projector Lamp for PT-LM1
How to reset lamp hour of panasonic pt d6000se lamp
Replace lamp
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
The lamp hour timer on the lamp housing, you can replace a new timer,
Posted on Dec 26, 2014
SOURCE: Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
This is a link to AVS for Panny PT-50LC (LCD) which I assume must be the same for the DLP.
With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds. The TV will be turned on and it will have a screen of status data atop an active TV channel. To get out of this mode TURN OFF your TV.
This initial "SERVICE MODE 1/3" screen shows -
LAMP OPERATION TIME
TOTAL :
CURRENT LAMP:
OSD DISPLAY :
LON COUNT :
Posted on May 12, 2008
SOURCE: I have a panasonic model
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Posted on May 14, 2009
welcomejee
  • 10594 Answers
SOURCE: After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Posted on Nov 18, 2009
  • 927 Answers
SOURCE: I have a PT-44LCX65 and replaced lamp accordingly
Howdy,
No, you must have the Remote.
Sorry, big IRISH.
Posted on Jan 02, 2010
pabloloco
  • 2335 Answers
SOURCE: reset lamp counter on my panasonic pt-52lcx16k
I can help you reset the lamp timer for your Panasonic PT-52LCX16 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Posted on Apr 15, 2010
How do you reset the lamp hours on a Panasonic PT-61LCX66-K
There probably is a service manual you can find on line to help you with how to reset the lamp hours.
http://www.manualowl.com/m/Panasonic/PT52LCX66/Manual/289575
Nov 11, 2014 | Panasonic Televison & Video
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
RESET THE LAMP HOURS OF PT-LB60EA
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic HDTV 1080i Lamp out Panasonic 1080i 42" HDTV - - saying "lamp needs to be replaced, reset lamp" - - what does this mean and how do I fix it??
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Jun 01, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
How do you reset lamp hours back to zero on a Panasonic PT-D4000U projector?
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
Apr 13, 2009 | Panasonic PT-D4000U Projector
Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic ET-LAM1 Projector Lamp for PT-LM1 Logo
104 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
