Question about Kenmore Elite 30 In. Electric Self-clean Single Wall Oven Convection Stainless
Wall oven will not heat
Oven come on but will not heat
    Problem Solver:
  • 5 Answers
Have you tried replacing the element?
Posted on May 15, 2014
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Wall oven needs a reset- wont heat
Hello John, thank you for allowing me to assist you!
I understand your wall-oven is no longer heating. The wall-oven has a safety thermal to prevent the oven from overheating. If the unit will not bake or broil, more than likely the safety thermal has tripped. Other possibilities are incorrect power supply or faulty main control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Oct 27, 2013 | Frigidaire 30 in. Electric Gallery Series...
Removing oven element to install new one
Turn power off at service panel (220 volt circuit breaker). Remove screws from heating element mount on wall of oven. Pull heating element from wall of oven far enough out to see the where the wires/lugs are screwed to the heating element leads. Remove these screws. Replace element. Make sure screws on heating element lugs/leads are tight -- if not tight, arcing will occur.
Charlie
Jan 08, 2011 | Ovens
My 30" wall oven oven won't heat up. the clock works and it allows me to put in bake, 350 degrees, but the elements don't heat up. we had a storm and the power flickered on and off several times. is there...
There is a safety thermostat (thermal fuse) on the back wall of the oven that interrupts power from L1 to the Bake and Broil elements. This fails open on an over-temperature or over-current condition. The oven needs to come out of the wall to replace it - best left to a tech unless you are experienced in such things.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
Just won't heat food
we have a maytag wall oven. maybe the ignitor is bad. the oven usually heats up to 180* and no higher if it is the ignitor. the oven thermostat could be bad. we replaced the ignitor, the thermostat, and the oven control board on our oven before we got it to work. did not want to have to patch up our wall oven cabinet cutouts, is why we decided to try and fix ours.
Jun 19, 2010 | Maytag Ovens
Electrolux wall oven not heating after self cleaning -- fan is going -- but it is not heating
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 17, 2010 | Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Electric wall oven will not heat up
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Dec 22, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kenmore Elite 30 In. Electric Self-clean Single Wall Oven Convection Stainless Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
