Question about Whirlpool Washing Machines
No spin The washer dosn't spin during the spin cycle but can be turned by hand.where should I start fixing the problem after removing the outter shell?
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 517 Answers
Make sure the belt is on first..then check the filter.. if all was ok ..test the motor with a multi meter
Posted on Apr 21, 2014
Make a really loud noise during the spin cycle
I would check the wash tub. Remove any clothes and examine how the tub sits in the opening. If it is sagging it could mean that the support arms are broken.
Try turning it by hand. It should turn smoothly without any noise. When the washer is in the spin cycle does it sound like a jet engine? If it does, it probally needs new bearings. It can be expensive to fix. Get a few estimates. Hope this helps you.
Jan 07, 2011 | Samsung WF218AN Front Load Washer
My kenmore front loading washer is screeching during spin cycle and seems to be spinning poorly at times. what is going on?
The wash drum should spin smoothly by hand without much noise. It is supported with two sets of ball bearings. If the water seal fails, water starts to leak into the inner bearing and they start to rust causing a loud noise especially during the spin cycle. The only way to fix it is to replace the bearings and seal. It a big and expensive job to replace the bearings since you literally need to take your washer apart to get to the bearings. Sorry.
Oct 07, 2010 | Kenmore 44102 Front Load Washer
My washer sounds like a turbine engine during spin cycle
It is the bearing in the outter basket. Some of the units had 5 years on the outter baket. I am a service tech & fixed several of these.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer bounces when spin starts and seems nosie
If it is brand new are the transit bolts removed? try spin with nothing in it and see if it turns smoothly, if not there is something broken inside, id spins smoothly it will be a fault in the dampers.
Apr 18, 2010 | Frigidaire ATF6000ES Front Load Washer
LG Front Load moves and vibrates violently during spin cycle?
This is a mis-direction. I was informed that I needed to reinforce my floor to reduce the vibration . The problem persisted. Then it turned into a loud roaring when the washer went into spin cycle. I have disassembled the machine to find out that the root of the problem was caused by a leak occuring where the inner tub's spline shaft goes through the bearing assembly in the back. the leak degraded the bearings to the point that caused the vibration to get worse and thus started a cycle of increasing distruction to the bearings untill the leak made its way onto and inside the electrical connectors for the stator. This shorted out the motherboard and totally distroys the machine to the point where the parts are more expensive to fix it then the machine is worth. To repair it you need to get the service manual to find out how to take it apart. After getting the inner and outter tub removed from the machine you need to totally dissemble the tubs so the rear outter tub that holds the bearings can be replaced. To troubleshoot if you have the same problem I had take the back plate off the washer and inspect the area at the bottom of the rotor. If you see any rust or water discoloration trails then start taking the machine apart before the motor shorts out the motherboard and kills the machine.
Feb 14, 2010 | LG WM-2277HW Front Load Washer
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
