Change from fsb 400 to 533 - Computers & Internet
    Brigadier General:
  • 3,400 Answers
Http://www.computerhope.com/jargon/f/fsb.htm
READ THIS CAREFULY MAYBE INVEST IN A NEW MOTHERBOARD.
Posted on Apr 24, 2014
Imperial gl ve 20020930 SPECS
TriGem (Company) Imperial GLVE (Model)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07813&lc=en#N779
http://www.trigem.co.kr/tgservice/econsult/faqProduct04.asp?cls=0&Page=&ID=4237&C1=1&C2=68&C3=359&C_N=IMPERIAL-GLVE
Hmmm, I'm at a stalemate.
Looking at the specs for the motherboard chipset;
The Northbridge and Southbridge chip,
Intel 845GV
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Supports CPU's with a 400MegaHertz Front Side Bus, or a
533MHz FSB.
Naturally I can't get a clear picture of those jumpers, but they look to be 3-pin.
If we are to assume that the jumper pins set the CPU FSB support, from 400MHz to 533MHz, then the jumper cap is moved from either
Pins 1 and 2, to Pins 2 and 3; on J2 jumper;
Or Pins 2 and 3, to Pins 1 and 2.
I know !O_O!
Sort of a guessing game, as to where the jumper cap goes to what pins, for 400MHz FSB support, or 533MHz FSB support.
Do you have any idea of what the FSB is for the old CPU (Processor), that was in the motherboard? (Or is)
Let's say 400MHz.
You now know if the CPU you are wanting to use, needs 533MHz Front Side Bus support, you need to move the jumper cap to the opposite pins.
What happens if it's wrong? Nothing. processor just won't work.
Change the jumper cap back.
(NOT plugged into power when you do. Also FOLLOW Anti-Static Precautions)
Yes. I'm 'out there on a limb'
I am assuming after looking at the TriGem support page, for the Imperial GLVE motherboard, that the J2 jumper is used to change the FSB support for the Processor.
It MAY be that J2 has Nothing to do with CPU Support.
It may be that there is no jumper for changing CPU FSB support.
(Cleared that right up, huh? Geez!)
For additional questions please post in a Comment.
Regards,
joecoolvette
[J1 = FDD. Floppy Disk Drive
J2 = CPU FSB jumper
J3 = CMOS Setup
J4 = CMOS,
IMHO ]
Feb 19, 2013 | Computers & Internet
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
Mar 15, 2010 | HP Pavilion dv1000 Notebook
I have an Ms-7037 motherboard. I want to change
You cannot change the FSB to 800 , the board is made to take certain FSB's and processors are made with certain fsb speeds (Mainly 533mhz , 800mhz , 1066mhz etc)
These speeds cannot be changed . You have to buy a new processor and a new board to get the faster speed FSB !
If you found this solution useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Motherboard
I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Changed cpu on an abit va-10 mb but the fsb stays at 266
Unless the mobo is compliant with a front side bus speed of 333mhz, the cpu you have will only run at 266mhz max, in other words the cpu will down-clock to the 266mhz bus clock and therfore run more slowly. check with the mbo handbook, or on CMOS tosee if yoy can change the fsb setting. ask for more help if needed.Can you give me the full code of the mobo ?
Nov 29, 2008 | Abit VA-10 333MHz FSB VIA VT8378 Chipset...
Motherboard capable of running 533 fsb, running at 133
You would have to run the 533 FSB at times 5 or 6 to get 2.4GHZ.
And if you did you probably would not see any increase in speed
Just because a computer can do something does not mean it should
Nov 03, 2008 | Computers & Internet
ASUS P4S333-M What is the maximum CPU this bouard will run
P4S533-MX
The following table shows the support for CPU / Motherboard
CPU
Since PCB
Since BIOS
Note
Celeron 1.7 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 1.8 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.0 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.1 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.2 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.3 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.4 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.5 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.6 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.7 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.8 GHz (400 FSB, L2 cache:128KB) ALL
1006
P4-1.4 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.5 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.7 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.9 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2.20 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.26 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.40 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.40B GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.50 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.53 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.60 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.66 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.80 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-3.06 GHz (533 FSB, L2 cache:512KB, HT, C1/D1) ALL
ALL
Since PCB 2.0 or later support HT Function
Jun 22, 2008 | Computers & Internet
System memory FSB
Have you tried installin the memory in various slow...ie 1,2/1,2/1,4 etc?
Its sounds like your mother board is unable to run the sticks at the rated speed as they are different brands and densities so its dropping the speed to 166.
Have you tried going into the bios and changing the ram speed there?
Also try changing the command rate from 1T to 2T to see if that helps.
Dec 29, 2007 | Computers & Internet
Processor upgrade
f you want model #s, Dell support will furnish them. However, the GX260 is a P4/400,533 FSB system, so a 2.4 would not pose a problem.
I've installed 2.8 before with no worries.
Good luck
Nov 07, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
