Fuse's 15 5amp , fuse 13 20amp an fuse 5 15amp located in the central junction box . Inside the vehicle under the dash right or left side . you'll have to look .
It is located in the central junction box , fuse # 10 - 7.5amp - fuse # 13 20amp , check # 9 too 7.5amp .
Central Junction Box
Left side of vehicle, below instrument panel
It could be either.....Cruse Control vacuum hose off or has cracks (located inside the engine area) or the 'kick-off' switch located on the brake peddle is bad. That being said, the lid of your fuse box should have a list of what each fuse is and location....also will be in your owners manual.
If you tinkered under the hood you may have un-plugged a vacuum hose that makes the cruse control work ,look under the hood for un-plugged tiny vacuum hoses,I have had this happen to me
CORRECT THEIR IS A RELAY USUALLY LOCATED UNDER HOOD IN FUSE BOX GET YOUR WONERS AMNUAL TO LOCATE WITCH ON AS THE CRUSE ON CAD. IS WIRED INTO LIKE 3 DIFFERENT RELAYS NOT JUST ONE DEDICATED TO IT
I would start by checking the fuses on that circuit.look in owners manual under (fuses) Locate fuse block and look for a blown fuse.There might be a relay fuse under hood
Hello s poteet> My name is Roger and I will help you. The fuse for the cruise control will be located in the fuse panel located on the left side of the steering column under the dash. Locate the fuse listed as METER. Should be second fuse up from the bottom in the middle row of fuses. This will be a 15 amp fuse and blue in color. This is the only fuse that pertains to the cruise control. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
hello. check you fuse panal. look in the user manual that came with the car. it will have a fuse panal diagrame of what fuses control what. check if the twight senenal is working. it might be burned out. it will be located behind down to the right of your cruse control on off switch. wiper switch top headlight switch mid- cruse bottom. your cruse control switch and your headlight switch will have to be removed to get at the twilight sentenal switch. mabe your turn signal lights are buned out. you can replace them. you will have to remove your speedometer panal to get at them. an other posabllity is that your turnsignal switch on the steering collom isn't working. I segest that you buy the haynes repaire book. you can get it at canadiantire. and online at amazon.com. your fuse pannal should be down on the bottom left on the drivers side underneath the dashboard where your parking break is.
