Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE side by side freezer, rhythmic whirring noise coming from freezer, at the top near ice maker.
Noise continues when ice-maker is off. This unit is 8 months old. Nothing should be going out. Ice buildup on the circulating fan? If so whats a long term fix? The noise occurs all the time, but the noise it self isnt constant. Almost like a reving, noise goes whhr, silent, whrr, silent, whhrr silent. I thought maybe it was the unit that dumps the icecubes over, like something was stuck and that motor was still going. But I'm not sure.
    Novelist:
  • 150 Answers
Typically the freezer fan motor should be replaced, the issue usually lies with the tachometer within the fan motor, the main control board is not sensing the proper speed of the fan motor and therefore can't operate it correctly. In many cases the main board gets replaced too to ensure the most up to date software, as GE has had NUMEROUS software revisions on those main boards over the last 11 years. You would need to capture the complete model number from the appliance it's self in order to see if your main board has had preceding part numbers. Pleazer Appliance...
Posted on Apr 20, 2014
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: GE GSS20IE Ice Maker
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date.  Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you.  Call 1-800-905-9505 for service.  They are nationwide (US).  If you find out it is older than 1 yr then use the model # on that sticker and go to www3.sears.com to get the correct part # for the icemaker.  Unfortunately these come as a whole unit and can't replace parts.  Once you have the correct part # I bet will find a good price on ebay for a new ice maker.  If you need help finding the part # or any other questions let me know.  If you feel I didn't help solve your problem please let me know before you rate this solution.
Posted on Oct 13, 2007
SOURCE: Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Posted on Aug 08, 2009
  • 32 Answers
SOURCE: GE side by side freezer not working - ice buildup
check the defrost timmer if it is working you need a defrost heater you can manually turn the defrost timmer to check the heater the timmer turns off the compressor and on the heater 2 or 3 times a day the timmer is a box with a round knob sticking out of it turn the knob tell it clicks look under the front for it or in the back most refrigerators have a wiring diagram on the back or by the compressor
Posted on Oct 20, 2009
  • 794 Answers
SOURCE: My GE Model GSL25XGWA SS
Hi davidrothe,
There are some things that you can check to address the issue with the icemaker that overflows:
1. Gears - The first thing you should check are the gears on the front of the icemaker. To access these gears; remove the front cover off the icemaker.Once the cover is off, inspect the gears and if any of the teeth are missing they are bad and needs replacing. Also check to see if the small gear has slid forward enough to miss the big gear. If so, put a small drop of lock tight on the shaft and push the gear back on.
2. Fill tube - The next thing you should do is look at the fill tube to see if it is clogged with ice. If it is clogged with ice, pull it out the back of the refrigerator and clean all the ice out with hot water. The water valve causes this problem so replace the water valve or it will happen again.
3. Sometimes water will enter the icemaker too fast causing the first cube-mold to overfill before the water gets a chance to run to the other cube-molds. To fix this problem remove the cube separator and run a bead of RTV (silicone) at the top of the first cube mold. Then reinstall the cube separator and the problem should be fixed. Note that if this is the problem it will only be a small leak; a few drop of water per cycle. If you are getting lots of water overflowing the water valve is bad and needs replacing.
The most common problem with noisy refrigerators is the fans. First, where is the noise coming from? If it's coming from the freezer then it's probably the evaporator fan motor. Take the evaporator cover (in back or bottom of freezer) off. Once it's off you should be able to see the fan and confirm that it's noisy. (Note that in some refrigerators the fan cuts off when you open the door so depress door switch for this test). If the fan is noisy replace it. If its not the fan and the noise is coming from the freezer, then it might be normal. At times there will be a groaning noise coming from the freezer. This is when the compressor has just cut off.
Hope it helps.
Thank you for using FixYa.
Posted on May 11, 2011
How do i fix a loud noise coming from my frigidaire glrs264za refrigirator?
Sounds like you have ice buildup next to the evaporator fan that circulates air inside the fridge. Ice buildup happens due to too much moisture - door open for extended periods, leaky door seal, heating system meant to de-ice the fridge not doing its job. You can approach this two ways. Unplug and leave both sides of the fridge open for at least 24 hours to let it thaw, or open up the fan cover and thaw it with a hair dryer (fridge unplugged ofcourse). Option two is faster, but more labor intensive. This wont solve the underlying problem of ice buildup, but will get rid of the noise for some time (likely months).
Sep 06, 2014 | Refrigerators
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
Refrigerator intermittent humming sound
If it's not causing any problems to the overall operation of the unit itself, I wouldn't worry about it.
May 14, 2012 | Sub-Zero Refrigerators
Hi, I have a Kitchenaid side-by-side refrigerator, and the ice maker has significant ice buildup in the chute. It's still making ice, but the buildup is pretty bad. Any idea how to fix this?
Hi Caiello,
I believe this is an overflow problem from the ice maker itself. Turn off the ice maker (this is done by raising the arm on the side of the unit), let it finish the cycle and dump into the bin. Let the ice maker stand for a day or so, then you may be able to remove the buildup. Restart the ice maker, and see if there is excess water coming from the unit. If it continues to overflow, there may be a problem with the unit itself
Hope this is of assistance,
Joe
Sep 13, 2011 | KitchenAid Refrigerators
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
GSs 22 wg refrigerator humming noise from freezer. Tech came and replaced defroster heater element but humming remains. What is the likely cause of this? It comes and goes but is mostly on. Fridge...
most likely it's coming from the evap fan motor or the ice maker,try shutting the ice maker off first to see if that's the problem,if not then i'd go with the fan motor,you can try opening the freezer door,this usually turns the fan on,then push in the door switch button and see if the fan stops blowing and if the noise stops too.hope this helps you out.
Jun 12, 2011 | GE Refrigerators
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
My Samsung rs 2556 SH side-by-side fridge is making a loud whirring noise, but when I open the fridge the noise comes to a sputtering stop. It starts again a few seconds after being closed. Noise sounds...
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
May 18, 2010 | Samsung RS2630WW Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
121 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
