Question about Craftsman 10" Table Saw
Saw won't start. Sometimes it kicks over foe a couple of turns but won't go.
  • 3 Answers
It maybe a faulty on/off switch. I would maybe try to by-pass the switch just to see if it is. If that is not the case then there maybe something wrong with your motor.
Posted on Apr 19, 2014
I have a Stihl 039 chainsaw that kicks back when starting.
check for a sheared or bent flywheel key...
Dec 03, 2013 | Stihl Garden
'04 L300-3 Stalls randomly and won't start until I wait about 5 min. Then starts normal
try replacing fuel filter , and next time you go to start it turn key on let it sit for count to 50 then start see what happens
Dec 14, 2012 | 2003 Saturn L-Series
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
When I flip the switch it foes not run. I used the saw for several cuts, I tried to rip another pirce and it just wold ot run. Tried the rset button and it seems like it is stuck. Wwiriing is all...
Sometimes switch gets dust inside the "sealed" switch. Had 50/50 luck taking apart and blowing out. Can test it after switch is out to see if it is faulty by jumping wires.
Aug 26, 2011 | Delta Machinery 10" Left Tilt Contractor'S...
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 04, 2011 | Maytag Dryers
Almost new Powermatic 220V saw. Sometimes starts very slow as if one leg is energized and will kick breaker if i don't turn if off immediately. I can then hit start again and it runs fine. Sometimes...
Assuming that this is a three-phase motor, suspect a defective motor starter (look for loose parts or poor contact condition). If the starter is equally new, does it have any warranty? Check the wiring connections for anything loose (motor, starter, source). Good luck!
Jan 17, 2011 | Garden
Chain saw motor runs but chain doesn't
There are a couple of reason the saw blade will not turn.
- Make sure you have bar and chain oil in saw.
-Make sure oil is running on the saw blade and chain.
-Make sure the clutch is not stuck.
- Make sure the bar sprocket is not frozen.
-The safety kick back guard needs to be re-set.
-Shut off saw. Push and pull guard.
Please let me know what you find.
Feb 10, 2010 | Garden
I recently (8 days ago) changed the starter on my Unisaw. A couple of the wires from the plug on the origional starter were loose, and the saw would kick off as soon as I turned it on. Now my saw has done...
What is the rating of the starter overloads. A more basic question, are they adjustable or the heater type? It sounds like the starter overloads are taking you out. Check the full load amps of the motor you are using against the overload rating. Add 10% to this and set overloads at ths setpoint if adjustable. If heater equipped buy new heaters rated for motor load. Make sure to use the 1 phase rating and not the 3 phase. That is if you are using a 3 phase starter.
Oct 03, 2009 | Delta X5 3Hp Left Titl Unisaw with...
I have a Skil 10'' table saw that will not power on.
If your switch is in the base of the machine, like some portable table saws. The switch may be full of saw dust. I hade one that the reset switch couldn't be pushed to reset because the housing was packet with saw dust. I simply opened the cover and vacuumed it out. If you open your switch box up and it is clean inside, your switch is probably bad. You can check it by taking the two wires off your switch (with the saw unplugged of course) and taping them together, if the saw works when you plug it back in, get a new switch.DON'T use your saw wired this way.
Mar 26, 2009 | Saws
Craftsman 10" Table Saw Logo
59 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
