Question about Duplo Office Equipment & Supplies
Roller ejecting problem in duplo dp205a - Duplo Office Equipment & Supplies
Duplo dp21 s2 master set miss
Behind the cutter unit is A black sponge roller, turn it manually by hand, you will find A small piece of master/stencil there. Remove it and reload the master/stencil roll.
Aug 15, 2011 | Duplo DP22L Black and White Copier
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Duplo DF-520 Error Code
you will find it in the operation guide. i uploaded the pdf copy here: http://www.mediafire.com/view/?7wvzv3jqwcyga1g
Jan 15, 2010 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
Master Missed
hi im jules_09.the is a broken or defective gear at the drive roller at the back check it then replace
Dec 06, 2007 | Duplo DP21L Copier
24 people viewed this question
Top Duplo Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
Sandra Sparks
Sandra Sparks
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
